I am trying to register AutoCAd 2010. We have 2 disc sets. I was able to register disc 1 sucessfully. When I enter the 2nd disc an error message says the serial number is registered to a different company. Now what do I do?
SN XXX-XXXXXXXX
This post has been editied to remove the Sertial Number and Activation Code.
contact your reseller to know to what exactly name is used for company to that serail number.
Perhaps an error occured during the registration of the product.
You can use this form also to contact Autodesk directly.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13682581
Franck is right. I checked the registration before the Admin removed the serial number (never ever ever ever ever post your serial number) and it is *not* registered to Hartford Habitat for Humanity. For security purposes, I cannot tell you the registrar. If this was purchased from another organization, you might need to fill out a TOL with the reseller to show that you are the new owner of the license. Only your reseller can help you with this issue.
