• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Employee
    Re: error-1722 while installing revit structure 2013
    11-14-2012 08:24 AM in reply to: paresh6203
    The only other thing I would think to try is to again remove Revit using the Microsoft Fix It utility then reinstall following the steps from the following document.
    http://usa.autodesk.com/getdoc/id=TS75218
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    Please use plain text.
    New Member
    PierreFINIELS6147
    11-14-2012 09:00 AM in reply to: DannyHubbard
    I had exactelly the same problem with autodesk robot structural analysis 2013. The only solution that I have found after two weeks of test is to reinstall windows. After every thing has working well. Perhaps a windows repair with CD is possible, or with the sauvergard initial CD of your computer.
    Unfortunetly it's a lot of work to reinstall all yours softwares.
    If somebody has a better solution it will be great
    Pierre Finiels
    11-14-2012 09:22 AM in reply to: DannyHubbard
    no danny that didn't work for me...thanks for giving me yr valuable time...now  i have give up.....
    and thanks pierreFINELS6147 for that solution....but i dont want to reinstall windows..as u said its lot of work to istall other program.....but thanks  :smileyhappy:
