• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    error-1722 while installing revit structure 2013
    692 Views, 22 Replies
    11-09-2012 03:25 AM
    i am trying to install revit structure 2013 on my win7 x64...error comes while installatin ( error -1722 ) ...pls someone help
    Please use plain text.
    Employee
    Re: error-1722 while installing revit structure 2013
    11-09-2012 05:18 AM in reply to: paresh6203
    Reboot, try the install again. If it still fails post the Revit Setup and Install log from your temp folder, they will have more details on the cause of the failure.
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    11-09-2012 09:12 AM in reply to: DannyHubbard
    thanxx for reply danny
    there are two log file for revit 1- install.log and 2- satup.log....whitch one is nedded?
    Employee
    11-09-2012 09:31 AM in reply to: paresh6203
    Attach both log files.
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    11-09-2012 09:40 AM in reply to: DannyHubbard
    here it is...satup.log file
    size of install log is about 14 mb..what to do?
    Employee
    11-09-2012 09:50 AM in reply to: paresh6203
    Select the install log, right click choose Send to - Compressed Folder.
    Uploading the resulting zip file that is created.
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    11-09-2012 09:53 AM in reply to: DannyHubbard
    thanks danny ...here it is :smileyhappy:
    Employee
    11-09-2012 10:05 AM in reply to: paresh6203
    Your install log is reporting the following error
    Note: 1: 1722 2: win64RegisterIDbRoot.742DD471_03BC_4C75_8992_518E2BDABD1C 3: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\ 4: regsvr32.exe /s "IDbRoot.dll"
    Try renaming this DBAccess folder then run Setup again to install Revit.
    See a similar post, http://forums.autodesk.com/t5/Installation-Licensing/Cannot-Install-Revit-2013-Something-called-Wind...
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    11-09-2012 10:14 AM in reply to: DannyHubbard
    ok i read that post...he is saying
    "In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again."
    but not mensioned renamed file... ?????? so can i ename it to any name?
    Employee
    11-09-2012 10:29 AM in reply to: paresh6203
    Yes you can rename the file to anything. Make sure you read the rest of that thread there are other things people did to get past this error.
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
