i am trying to install revit structure 2013 on my win7 x64...error comes while installatin ( error -1722 ) ...pls someone help
Reboot, try the install again. If it still fails post the Revit Setup and Install log from your temp folder, they will have more details on the cause of the failure.
Danny
thanxx for reply danny
there are two log file for revit 1- install.log and 2- satup.log....whitch one is nedded?
here it is...satup.log file
size of install log is about 14 mb..what to do?
Select the install log, right click choose Send to - Compressed Folder.
Uploading the resulting zip file that is created.
Danny
Your install log is reporting the following error
Note: 1: 1722 2: win64RegisterIDbRoot.742DD471_03BC_4C75_8992_518E2BDABD1C 3: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\ 4: regsvr32.exe /s "IDbRoot.dll"
Try renaming this DBAccess folder then run Setup again to install Revit.
See a similar post, http://forums.autodesk.com/t5/Installation-Licensing/Cannot-Install-Revit-2013-Something-called-Wind...
Danny
ok i read that post...he is saying
"In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again."
but not mensioned renamed file... ?????? so can i ename it to any name?
Yes you can rename the file to anything. Make sure you read the rest of that thread there are other things people did to get past this error.
Danny
hello danny...my problem is...
i am trying to install revit structure...installation stopeed by error 1722...then i have renamed that file u mensioned...then i again trying to install revit....but installation window shows that it is alreaday installed.
i have tried to uninstall it from control paned...but i cant....then i complete uninstalled it by microsoft fix it programe....so the problem is ..if i complete uninstall it...then there is no file or folder of revit structure in autodesk shared folder...so i thing there is no meaning of renaming that file and installing again......sorry for my bad english :D...m very confused..pls reply..thanks danny
"error 1722. there is a problem with this windows installer package a program run as a part of the satup did not finish as expected. contact your supprot personal or package vendor." 😞
So after the uninstall using the Microsoft Fix It utility did you verify that the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" didn't exist before trying to install Revit again?
The uninstall won't remove everything, especially things in the Autodesk Shared folders.
Danny
someone also have the same prob. here is the link...
i dont know him problem has been solved or not...because i cant understand that language.. 😞
When installing Revit now are you still getting the 1722 error?
If you look through the Revit Install log in your temp folder is it still the same error as before?
Danny
yes danny .. i m getting same error...installtion starts ...takes time for small window ( installing revit content ) then suddnly error comes 1722.
i dont understand about logs...so here i m attaching my new log file
The error message is the same as before. Like I mentioned previously in Windows explorer navigate to "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013" and rename the DBAccess folder, add a 1 to the end of the folder name or something. Then rerun the Setup for Revit.
Danny
hello danny...the problem is icant install revit structure again because installation windows shows it is already installed...and i cant uninstall it from control panel...i have to uninstall it by microsoft fix it prog. and if i remove that by microsoft fix it...then there is no DBAcess folder.
