Trying to re-install inventor LT suite and I keep getting the 1402 error message. How do I fix this?
1402 error is your user right not have sufficient access to some registry key. so I would suggest you use the OS default user "Administrator" to install and disable any anti-virus and firewall progresses.
also you can try this solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=10297059&siteID=123112
