an article from Autodesk Knowledge base
Applies to:
AutoCAD® 2007
Issue
While installing AutoCAD® 2007 from a local or shared hard drive, you
received the following error message:
Error 1308. Source file not found.
Solution
This error may occur if the installation disks were copied to different
folders. The contents of both CDs must be located in the same folder.
When you copy the second CD into the folder where the first CD files are
located, you will see a message similar to the following: "This folder
already contains a file named 'acadcd.mid'." Click the Yes to All button.
Once you have copied both CDs, double-click the setup.exe file to proceed
with the installation.
Franck Hervet
www.aricad.fr
a écrit dans le message de news:
5460385@discussion.autodesk.com...
I had the same problem at a client.
We used mapped drive.
Then copied all the files to the local pc.
Then installed a DVD rom.
Removed flush player
Logged in as administrator on local pc.
Checked free space.
Created new c:\temp folder and changed the temp=c:\temp and tmp= c:\temp
Antivirus stopped and firewall turned off.
Still no joy.
2 days later.
Please help me as well.
