Running Windows XP professional and Maya 2011 subscription Pack.
Initially Maya worked fine until installation of SP 1. Now I'm getting Error [0.0.0] and this:
License was not obtained
Tried Maya 2011 (), error 20
License method:
environment variable MAYA_LICENSE_METHOD = "network"
Product choice:
environment variable MAYA_LICENSE = "unlimited"
License file override:
environment variable MAYA_ALT_EN is not set
Funny enough all other programs in the pack (Softimage, Mudbox and Motion Builder) work just fine without a glitch.
I tried uninstalling and re-installing the whole package few times already but to no avail. All work except for Maya.
Any suggestions would be greatly appreciated. Thank you.
Solved by hashim.mundol. Go to Solution.
Please try link
Thanks so much Hashim, it worked
I actually had to uninstall the entire packge then go in and manually delete all files and folders that had anything to do with Autodesk, Maya, FLEXnet (especially FLEXnet), etc. After rebooting my comp I made sure once again I haven't missed anything. Then performed a clean install of the whola package and everything worked like a charm 🙂
The third entry on the link Hashim provided goes into more detail:
Hope it helps you guys.
