i have a floating license server for Autodesk Education Master Suite 2012 in italian language.
Is it possibile connect a Autocad 2012 in english language?
It's very important for foreign students to use english version...
thanx
Carlo
Solved by carlo.savi. Go to Solution.
Hi Carlo,
The FLEXnet license manager uses the same feature code for all language versions of the same product. For example, English and Italian AutoCAD 2012 clients can both receive their licenses from the same pool.
Note: The feature codes for all languages must be combined. The license manager is not able to support multiple instances of the same feature code in one license file. Contact your Autodesk Business Center for assistance in combining multiple language products under one serial number before you contact the Authorization department for your license file.
I have installed italian license server and i have connected succesfully english client too. Thanx for help!
