Installation & Licensing
downloaded Inventor trial - cannot get it to install
1 REPLY 1
348 Views, 1 Reply
downloaded the 30 day trail, but cannot install tried many times, switched off antivirus, Autocad starts to install but after a few seconds get the attached error page, meassage says inventor and design 2012 failed.
2012/10/1:16:58:56    SHoward    SAMSUNGLAP1    === Setup started on SAMSUNGLAP1 by SHoward ===
2012/10/1:16:58:56    SHoward    SAMSUNGLAP1    Launch
2012/10/1:16:58:57    SHoward    SAMSUNGLAP1    Inventorui== Parameter: Prereq_2 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/10/1:16:58:57    SHoward    SAMSUNGLAP1    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/10/1:16:58:57    SHoward    SAMSUNGLAP1    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/10/1:16:59:11    SHoward    SAMSUNGLAP1    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/10/1:16:59:11    SHoward    SAMSUNGLAP1    PageOpen    LaunchDialog
2012/10/1:16:59:21    SHoward    SAMSUNGLAP1    PageOpen    LicenseDialog
2012/10/1:16:59:27    SHoward    SAMSUNGLAP1    PageOpen    ProductInfoDialog
2012/10/1:16:59:31    SHoward    SAMSUNGLAP1    PageOpen    ProductSelectionDialog2
2012/10/1:16:59:45    SHoward    SAMSUNGLAP1    PageOpen    FullProgressDialog
2012/10/1:16:59:46    SHoward    SAMSUNGLAP1    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_LT_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\SHoward\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/1:16:59:47    SHoward    SAMSUNGLAP1    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
1 REPLY 1
philip.s
Hi Shane,
There may be a newer version of the Microsoft Visual C++ 2010 Redistributable Package installed on your computer which is causing the install failure.
A typical workaround is to uinstall Microsoft Visual C++ 2010 Redistributable (x86) via the Control Panel (add / remove programs), reinstall the software, and then install the latest version of Microsoft Visual C++ 2010 Redistributable (x86) from Microsoft (linked here).
For additional 1603 error causes and corresponding solutions, click here.
Please accept as a solution if this fully resolves the issue, or reply with specifics if the problem still persists.
Administrator Productivity
