I work in a company that is a partner of Autodesk.
I agree to the download page and I can not enter to download Product Design Suite Standard.
No works listed links
Please help me!!!
Solved by DarrenP. Go to Solution.
Solved by mconway. Go to Solution.
Select "redireccionese a la pagina de descargas" this should take you to the Product download page. Make sure you select the correct bit size (32 or 64) and use the "Browser Dowload" Option so that you recieve a copy of the software.
I have attached a video
https://www.dropbox.com/s/wlqxr0eps5fylbm/How%20to%20download%20my%20Upgrade.mp4
as an alternative you can go this route:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links
Please accept as a solution if this fully resolves the issue
DarrenP
