Installation & Licensing
directx runtime failure on AutoCad 2014
5 REPLIES 5
bk
Observer
6841 Views, 5 Replies
trying to install autocad 2014 LT onto my windows 7 computer.  I had a trial version of 2013 on it and now want to upgrade and purchase it - but it isn't loading.
I looked at a few other of similar cases, but they seemed to be from earlier versions of autocad...
AND GOD KNOWS, THERE ISN'T A FRICKING PHONE NUMBER TO CALL AUTOCAD!!!
Here is the log file that was saved:
2013/7/24:08:24:02 bk BK-BAZINGA === Setup started on BK-BAZINGA by bk ===
2013/7/24:08:24:02 bk BK-BAZINGA Path_Length: 152
2013/7/24:08:24:02 bk BK-BAZINGA Current Directory C:\Autodesk\AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us
2013/7/24:08:24:02 bk BK-BAZINGA Launch
2013/7/24:08:24:02 bk BK-BAZINGA CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us_... /akamai /auth authparam /sid SESSION_ID
2013/7/24:08:24:02 bk BK-BAZINGA Current Directory C:\Users\bk\AppData\Local\Temp\_AI4397.tmp
2013/7/24:08:24:51 bk BK-BAZINGA === Setup ended ===
2013/7/24:08:24:05 bk BK-BAZINGA === Setup started on BK-BAZINGA by bk ===
2013/7/24:08:24:05 bk BK-BAZINGA Path_Length: 152
2013/7/24:08:24:05 bk BK-BAZINGA Current Directory C:\Users\bk\AppData\Local\Temp\_AI4397.tmp
2013/7/24:08:24:05 bk BK-BAZINGA Launch
2013/7/24:08:24:32 bk BK-BAZINGA Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2013/7/24:08:24:51 bk BK-BAZINGA Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2013/7/24:08:24:51 bk BK-BAZINGA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\bk\AppData\Local\Temp\_AI4397.tmp\Setup\AcSetup.dll
2013/7/24:08:24:51 bk BK-BAZINGA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/24:08:24:51 bk BK-BAZINGA PageOpen LaunchDialog
2013/7/24:08:27:42 bk BK-BAZINGA PageOpen LicenseDialog
2013/7/24:08:27:45 bk BK-BAZINGA PageOpen ProductInfoDialog
2013/7/24:08:27:49 bk BK-BAZINGA PageOpen ProductSelectionDialog2
2013/7/24:08:27:51 bk BK-BAZINGA PageOpen FullProgressDialog
2013/7/24:08:27:52 bk BK-BAZINGA Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2013/7/24:08:27:56 bk BK-BAZINGA Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2013/7/24:08:27:56 bk BK-BAZINGA Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD LT 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/24:08:29:26 bk BK-BAZINGA Install DirectX Runtime Succeeded
2013/7/24:08:29:26 bk BK-BAZINGA Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2013/7/24:08:29:45 bk BK-BAZINGA Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2013/7/24:08:29:45 bk BK-BAZINGA Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/24:08:30:21 bk BK-BAZINGA Install Autodesk Material Library 2014 Succeeded
2013/7/24:08:30:22 bk BK-BAZINGA Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2013/7/24:08:30:41 bk BK-BAZINGA Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2013/7/24:08:30:41 bk BK-BAZINGA Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/24:08:31:08 bk BK-BAZINGA Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/24:08:31:09 bk BK-BAZINGA Download Play ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2013/7/24:08:32:36 bk BK-BAZINGA Download Aborted ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2013/7/24:08:32:36 bk BK-BAZINGA Install Autodesk® AutoCAD LT® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/24:08:32:41 bk BK-BAZINGA Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/24:08:33:14 bk BK-BAZINGA Rollback Autodesk Material Library 2014 Succeeded
2013/7/24:08:33:14 bk BK-BAZINGA Rollback DirectX Runtime Failed Failure is ignored, Result=1619
so Autocad - if you want me to spend my money - get this program installed on my computer!!!!
5 REPLIES 5
TravisNave
in reply to: bk
Welcome to the Community.
I understand your frustration, but the problem does not exist within the DirectX installation, but rather a problem downloading the software from the server.
I would recommend that you try downloading your product using Matt, the virtual assistant, by following the directions here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
As for telephone support, that is a service provided by your local Value Added Reseller.  If product support is important to you, then you should always purchased your software from a VAR rather than a big box / Internet store.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
bk
Observer
in reply to: TravisNave
I was going to buy it directly from Autodesk....is that not the best strategy?
TravisNave
in reply to: bk
There is no harm in doing so.  However, if you desire product support beyond the purchase, that is what the VARs are for.
Autodesk Forums:
oushakoffy
I am getting the exact same problem but when I click on your link it takes me to a help page but I can't find this virtual assistant?
pendean
in reply to: bk
Administrator Productivity
