Hi guys, i have big problem thanks to 'special' installer of AutoDesk products. I want to install software on computer with Win XP SP3 and its really frustrating but I cant. If I try to use autodesk download helper then it won't download anything and display error that it cant mantain connection to autodesk servers(or something similar). So i thought and downloaded installation files on another computer of mine and copy that via usb drive. Still it isn't enough because installer will display me after few seconds that it cant load deployui.dll. I already reinstalled net framework and directX. I even stopped firewall but still i cant even start installation...
BTW. Of course i'm using administrator account.
I would appreciate if anyone knows how to deal with this issue.
Matt
Welcome to the community!
Downloading large suites is generally problematic. I would recommend downloading them from Matt, the virtual assistant. Follow the instructions here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
depending on the 2014 suite
some of the suites will not allow you to install on XP
system requirements for the suites
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=16490792
DarrenP
