Installation & Licensing
Member
christopher.linz
Message 1 of 5 (3,675 Views)
d3dx9_43.dll missing
3675 Views, 4 Replies
12-10-2012 12:34 PM
I have downloaded 3ds Max using the download manager and have installed it successfully.  However, when I go to run it I get the error saying: This application has failed to start because d3dx9_43.dll was not found.  Although it then says: Re-installing the application may fix this problem, I doubt that will work and was wondering if there are other solutions to the problem.  I am trying to run the 64-bit version, by the way.  I should also mention that this is a student version I downloaded.
Active Member
_AdamN_
Message 2 of 5 (3,672 Views)
Re: d3dx9_43.dll missing
12-10-2012 01:56 PM in reply to: christopher.linz
Chris
I believe this is related more to your Direct X install then the Autodesk software. I see other users on the discussion groups have resolved the issue by installing the latest DirectX End-User Runtime Web Installer http://www.microsoft.com/en-us/download/details.aspx?displaylang=en&id=35
_____________________________________________________________
KarelCAD Application Support Specialist
Member
christopher.linz
Message 3 of 5 (3,605 Views)
12-15-2012 08:10 PM in reply to: _AdamN_
You were right, it worked.  But now I'm trying to run the program on a different computer and I get the message: The program can't start because MSVCR100.dll is missing from your computer.  Would this also be the same directX problem?  I tried doing the same thing as before, but when I run 3ds max, it still shows the same error message.  The program itself is on an external hard drive, so I didn't download it again, if that helps.  Also, this computer is Windows 7, where as the previous computer was Windows Vista.
Member
christopher.linz
Message 4 of 5 (3,599 Views)
12-15-2012 08:22 PM in reply to: christopher.linz
I actually just figured out I had to download another the file from Microsoft, but now it says that the software license isn't checking out.  Is that just because it can only run on one computer?  The reason I had to change was because the vista computer was too slow so I couldn't work with it.  If I download it directly from the education site again, will that make it work?
New Member
littlelilc
Message 5 of 5 (953 Views)
03-05-2014 05:48 PM in reply to: _AdamN_
thank you so much. this is really helping! :smileyhappy:)
FYI: I downloaded the student version and get notification "d3dx9_43.dll is missing"
