Installation & Licensing
nsaska
Message 1 of 29 (211 Views)
created install package but short cut is no longer .exe
211 Views, 28 Replies
08-22-2013 01:30 PM
created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!! :smileysad:
*Expert Elite*
TravisNave
Message 2 of 29 (204 Views)
Re: created install package but short cut is no longer .exe
08-22-2013 01:45 PM in reply to: nsaska
Welcome to the community.
Nothing is attached.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
nsaska
Message 3 of 29 (198 Views)
08-22-2013 01:58 PM in reply to: TravisNave
been up since 1AM with the baby, screen shots are now attached
*Expert Elite*
TravisNave
Message 4 of 29 (186 Views)
08-22-2013 02:36 PM in reply to: nsaska
Is this a deployment wizard?
nsaska
Message 5 of 29 (184 Views)
08-22-2013 02:39 PM in reply to: TravisNave
yes, I created a deployment using the contents of the CD installation files
*Expert Elite*
TravisNave
Message 6 of 29 (182 Views)
08-22-2013 02:42 PM in reply to: nsaska
Is there a reason you needed to create a deployment instead of just running the setup?
nsaska
Message 7 of 29 (160 Views)
08-23-2013 06:38 AM in reply to: TravisNave
we're running SCCM 2012 and install most software via un-attended install using SCCM
*Expert Elite*
TravisNave
Message 8 of 29 (152 Views)
08-23-2013 08:22 AM in reply to: nsaska
I see.  If you just run the shortcut, does it launch the installer?  That's the purpose of creating the deployment.
nsaska
Message 9 of 29 (149 Views)
08-23-2013 08:31 AM in reply to: TravisNave
the short cut launches it starts initialzing but never goes anywhere
*Expert Elite*
TravisNave
Message 10 of 29 (145 Views)
08-23-2013 08:36 AM in reply to: nsaska
Did you make your deployment correctly?
You need to make a shared folder on the server with full write access to everyone and configure the deployment to run via that UNC path.  I recommend \\servername\share, with full control to the everyone built-in user account.  I also recommend that you uncheck silent mode if you are having issues.
Don't use drive letters in your deployment or forget to set sharing *and* folder permissions on the location of the files.
Additionally, I do not recommend including a service pack with the deployment, initially.  Get everything working and tested first.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
