Installation & Licensing
created install package but short cut is no longer .exe
28 REPLIES 28
Message 1 of 29
nsaska
797 Views, 28 Replies
created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!! Smiley Sad
28 REPLIES 28
Message 2 of 29
TravisNave
in reply to: nsaska
Welcome to the community.
Nothing is attached.
Autodesk Forums:
Message 3 of 29
nsaska
in reply to: TravisNave
been up since 1AM with the baby, screen shots are now attached
Message 4 of 29
TravisNave
in reply to: nsaska
Is this a deployment wizard?
Autodesk Forums:
Message 5 of 29
nsaska
yes, I created a deployment using the contents of the CD installation files
Message 6 of 29
TravisNave
in reply to: nsaska
Is there a reason you needed to create a deployment instead of just running the setup?
Autodesk Forums:
Message 7 of 29
nsaska
we're running SCCM 2012 and install most software via un-attended install using SCCM
Message 8 of 29
TravisNave
in reply to: nsaska
I see.  If you just run the shortcut, does it launch the installer?  That's the purpose of creating the deployment.
Autodesk Forums:
Message 9 of 29
nsaska
the short cut launches it starts initialzing but never goes anywhere
Message 10 of 29
TravisNave
in reply to: nsaska
Did you make your deployment correctly?
You need to make a shared folder on the server with full write access to everyone and configure the deployment to run via that UNC path.  I recommend \\servername\share, with full control to the everyone built-in user account.  I also recommend that you uncheck silent mode if you are having issues.
Don't use drive letters in your deployment or forget to set sharing *and* folder permissions on the location of the files.
Additionally, I do not recommend including a service pack with the deployment, initially.  Get everything working and tested first.
Autodesk Forums:
Message 11 of 29
nsaska
yes I did. After I completed it I was able to successfully install it and uninstall it from my machine. Then someone walked into my office started talking to me and my mouse was over the files and I left clicked and some how that file became a short cut and ever since then I can't get it to start. I even deleted it and re-created the deployment. I'm starting to think it's something with my machine so I'm copying over the contents from the CD to a another machine and will re-create the deployment there also to eliminate my machine as the problem
Message 12 of 29
TravisNave
in reply to: nsaska
That's probably a good idea.  However, keep in mind that a deployment creates a shortcut and you launch it by traversing to the UNC path and running it that way.  It may just as well work from another workstation.
Autodesk Forums:
Message 13 of 29
nsaska
when you view your install.exe file in notepad or notepad ++ what do you see on your end? also want to eliminate that the original CD contents was corrupted by me
Message 14 of 29
TravisNave
in reply to: nsaska
That is irrelevant as there is no reason to launch your installation in notepad.
Autodesk Forums:
Message 15 of 29
nsaska
my new code that is now not working,
:: Set script parent directory: SET _ScriptDir=%~dp0 SET _ScriptDir=%_ScriptDir:~0,-1%
:: Run OS architecture check: IF NOT DEFINED PROGRAMFILES(X86) (  ECHO.  ECHO ERROR: 32-Bit Windows Operating Systems are unsupported! Exiting...  REM Delay for processing:  PING 127.0.0.1 -n 3 > NUL  EXIT )
:: Display status message: ECHO. ECHO Installing Autodesk AutoCAD 2014...
:: Run install commands: START "Install" /WAIT "%_ScriptDir%\SRC\x64\Setup.exe" /qb /I "%_ScriptDir%\SRC\x64\AutoCAD_2014.ini" /language en-us
:: Display completion notice: ECHO. ECHO Done!
:: Delay for processing: PING 127.0.0.1 -n 3 > NUL
:: Uncomment to view script results: :: ECHO. :: PAUSE EXIT
Message 16 of 29
nsaska
in reply to: nsaska
Message 17 of 29
TravisNave
in reply to: nsaska
This is usually an issue with an anti-virus program, like Trend Micro.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9243099&CMP=OTC-RSS...
Autodesk Forums:
Message 18 of 29
nsaska
this is the log from another installation attempt after I cleaned out my temp folder but the AV application is turned on by GPO so I'll need to see about getting around it
log:
2013/8/27:10:37:17 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:17 nsaska LAP5CB2442H61 CommandLine /MD "C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64\AutoCAD_2014.ini" /ML /language en-us   2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:59 nsaska LAP5CB2442H61 === Setup ended ===
2013/8/27:10:37:18 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:18 nsaska LAP5CB2442H61 The system cannot open the device or file specified. 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp\Setup\AcSetup.dll 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2013/8/27:10:38:00 nsaska LAP5CB2442H61 === Setup ended ===
Message 19 of 29
nsaska
in reply to: nsaska
Message 20 of 29
nsaska
in reply to: nsaska
just looked into this article - http://esupport.trendmicro.com/solution/en-US/1096841.aspx  but we are not even running TrendMicro on our machines
Administrator Productivity
