Found this in my c3d PSpack Install.log
MSI (s) (38:C0) [11:02:00:799]: Note: 1: 1722 2: RegisterCatalogs 3: C:\Program Files\Autodesk2014\Autodesk AutoCAD Civil 3D 2014\Aeccb.exe 4: /language "[LANG2LONG]" /product "C3D" -r
CustomAction RegisterCatalogs returned actual error code -1073741701 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (38:C0) [11:04:12:705]: Product: Autodesk AutoCAD Civil 3D 2014 - English -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action RegisterCatalogs, location: C:\Program Files\Autodesk2014\Autodesk AutoCAD Civil 3D 2014\Aeccb.exe, command: /language "[LANG2LONG]" /product "C3D" -r
Hello. Are you able to use the program? Is this a failed installation altogether or just a message in a log file? If you are unable to install cleanly, I would try to uninstall with the MS fixit tool and then reinstall
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Past this, if you have any on-screen errors, they may be useful. The log looks like there may be a connection to the language pack.
Thank you for taking part in our community!
This is a failed installaton. My log file has alsoway said civil 3d product specific pack failed installation aborted, result=1603. I have been trying for a long time to get civil 3d installed from deployment. I have posted here several times included my log files. I am just wishings I could find out what the problem is. I have civil 3d 2011 and civil 3d 2012 working but beyond that I can't get 2013 or 2014 installed. I tried other computers but get the same error 1722 error.
my on screen error has alwas been error 1722 windows installer package.
I have used msfixit several times.
Thanks for the ideas.
Make sure that your deployment has full write privileges to the share and folder permissions and that you do not have it checked for silent mode deployment, nor should you add any updates or service packs to the deployment.
