Oops, i guess that makes sense, I figured a network client is a network
client.
jerry milana wrote:
> The official, supported answer is to redeploy AutoCAD with a deployment
> built for the proper protocol. For sure, you can not just switch from IPX
> to TCP and keep the server name and get things to work. This is because the
> listening component of AutoCAD is protocol specific. See
> http://support.autodesk.com/getDoc.asp?id=TS12018 regarding the
> ADESKSYS.DLL. Note that switching these files may get AutoCAD running on
> TCP/IP it is not the supported method.
> Jerry Milana,
> Autodesk Professional Services
> "Dick" wrote in message
> news:90456CBD2B0D2581664A2869117AB0EA@in.WebX.maYIadrTaRb...
>>MLanan wrote:
>>>If you don't mind me asking - How did you change an old install of ADlM
>>>from IPX to IP? I am forced to move the licence manager off of a Novell
>>>server onto a W2K box, and I do not want to reinstall 60 LDD2's. TIA
>>I don't think you need to change anything at the workstation as long as
>>the server name stays the same.
