i downloaded the autodesk inventor 2011...the file was about 2.6 gb..bt when i am trying to install it,they are asking to insert the other part which has some other files..but the download link gave me only one compressed file...file name is AutoCAD_Inventor_Suite_2011_Win_64bit.part1..how will i install it?
you need to download part 2
you can download from here
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Inventor Products>Autodesk Inventor
Please accept as a solution if this fully resolves the issue
DarrenP
