Installation & Licensing
cannot install autocad 2013
3 REPLIES 3
865 Views, 3 Replies
Tried thousands of time to install autocad 2013, but i faild.
it's .net 4.0 framework issue.
Why you guys dont even to resolve this issue??????????
my system is win8 64.
PLEASE do something!!!!!!
Thanks!!!!
3 REPLIES 3
camilo.lemos
Hi wongbean,
Right now we officially support the products mentioned here on Windows 8, but keep checking as the list will be updated over time.
Camilo Lemos
TravisNave
You can try to modify your setup.ini to ignore the check for DOTNETFX.  See my post here for more information:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/m-p/3352895#M84974
Please note that this method is not supported nor is it guaranteed to make your software work.  Windows 8 is not officially supported.  Good luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: camilo.lemos
The main problem is autocad insist to install .net framework 4.0. But windows 8 has integrated with 4.5 and I cound not uninstall. So I went into a infinite Loop and nomater how I  tried, I just could not install that.
I just don't know why autocad must install that even I have install .net framework?
Administrator Productivity
