I write this message again, because th first was in the wrong discussion Group
Problem:
We had borrowed licenses for 180 days, we gave them back.
Then we have created a opt file with MAX_BORROW_HOURS 64400AMECH_PP_F 72 and forgot to activate the "Force server shutdown" in the lmtools when we have stopped and started the server.
Now I have again borrowed licenses which are really not borrowed.
We have this problem for 4 Users. See file 03 after restart of server user ligangfr and three other user again here.txt
(ligangfr & sfaspaas & wistauma & wypilsmi)
What can I do?
Welcome to the community.
Since the license server does not think they are borrowed, you have two choices:
1. You can just wait for the client machines to expire
2. You can manually remove the borrowed license from the registry.
To remove it, simply clear the following registry key:
HKEY_CURRENT_USER\Software\FLEXlm License Manager\Borrow
For more information, see this KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10305068&linkID=9240617
Good Luck!
Return the new borrowed license. Stop the server. Remove the options file temporarily. Start the server. Reborrow. Verify, then return. Then put back the options file. See if that works.
Hello again!
Here is also another protocoll:
There you see, that wen I shutdown the server the borrowed licenses of the wrong users like ligangfr end in 147841 minutes (102,6 days)
Then after restart the user gets and borrows a licence for 179,4 days, but he isn't in acad.
This happens to all 4 users !!!
log protocoll:
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" ligangfr@LI024906NB
Server status:
ligangfr LI024906NB LI024906NB (v1.000) (WYACLICWN/27001 301), start Wed 7/31 9:13 (linger: 15502260)
log protocoll:
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F wypilsmi/WY025240PC/WY025240PC exp: 35461 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F sfaspaas/SF021293NB/SF021293NB exp: 38281 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F ligangfr/LI024906NB/LI024906NB exp: 147841 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F wywallmi/WY024047PC/WY024047PC exp: 901 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F stkrafru/ST024494NB/ST024494NB exp: 901 minutes
8:56:56 (adskflex) BORROWED: 85733AMECH_PP_2012_0F wywallmi/WY024047PC/WY024047PC exp: 901 minutes
8:56:56 (adskflex) BORROWED: 85733AMECH_PP_2012_0F stkrafru/ST024494NB/ST024494NB exp: 901 minutes
8:56:56 (adskflex) Shutdown requested from SYSTEM@WYACLICWN IP=172.16.33.69
8:56:56 (adskflex) daemon shutdown requested - shutting down
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wypilsmi@WY025240PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" sfaspaas@SF021293NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" ligangfr@LI024906NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wywallmi@WY024047PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wistauma@WI025123NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" stkrafru@ST024494NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wystocso@WY020858PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" alfedool@AL490018PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wybachch@WY024256NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" bkpanalo@BK024806PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wyriglth@WY024048PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" brhatizu@BR024958PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" simuslmu@SI024009NB (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wyhenima@WY024059PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" duamorma@DU530020PC (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wytascbr@wy021783pc (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wydreith@wy020286pc (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wyriegma@wy021781pc (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wykatzmi@wy020333pc (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wywallmi@WY024047PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" stkrafru@ST024494NB (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wystocso@WY020858PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" alfedool@AL490018PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wybachch@WY024256NB (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" bkpanalo@BK024806PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wyriglth@WY024048PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" brhatizu@BR024958PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" simuslmu@SI024009NB (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wyhenima@WY024059PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" duamorma@DU530020PC (SHUTDOWN)
9:13:49 (adskflex) Server started on WYACLICWN for:
9:13:49 (adskflex) 64400AMECH_PP_F (consisting of: 59200AMECH_PP_2009_0F
9:13:49 (adskflex) 85545AMECH_PP_2011_0F 71800AMECH_PP_2010_0F 85733AMECH_PP_2012_0F)
9:13:49 (adskflex) 85814PDSP_F (consisting of: 59200AMECH_PP_2009_0F
9:13:49 (adskflex) 85795PDSP_2012_0F 85573INVBUN_2011_0F 85607SHOWCASE_2011_0F
9:13:49 (adskflex) 85615ALSK_2011_0F 85580MBXPRO_2011_0F 85545AMECH_PP_2011_0F
9:13:49 (adskflex) 85503MAXDES_2011_0F 85579INVNTOR_2011_0F 70400INVBUN_2010_0F
9:13:49 (adskflex) 83900MBXPRO_2010_0F 71800AMECH_PP_2010_0F 70000MAXDES_2010_0F
9:13:49 (adskflex) 85577INVNTOR_2010_0F 59300INVBUN_2009_0F 612003DSMAX_2009_0F
9:13:49 (adskflex) 70200MBXPRO_2009_0F) 59200AMECH_PP_2009_0F PLIST
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wypilsmi@WY025240PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" sfaspaas@SF021293NB
9:13:49 (adskflex) OUT: "85733AMECH_PP_2012_0F" wywallmi@WY024047PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wywallmi@WY024047PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wistauma@WI025123NB
9:13:49 (adskflex) OUT: "85733AMECH_PP_2012_0F" stkrafru@ST024494NB
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" stkrafru@ST024494NB
9:14:24 (adskflex) TCP_NODELAY NOT enabled
9:14:24 (adskflex) OUT: "64400AMECH_PP_F" mokulbok@MO520221PC
9:14:24 (adskflex) OUT: "85733AMECH_PP_2012_0F" mokulbok@MO520221PC
9:14:33 (adskflex) OUT: "64400AMECH_PP_F" wyriglth@WY024048PC
9:14:33 (adskflex) OUT: "85733AMECH_PP_2012_0F" wyriglth@WY024048PC
9:14:39 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyhoenan@wy021768pc
9:14:41 (adskflex) OUT: "64400AMECH_PP_F" hhdinhin@HH700103PC
9:14:41 (adskflex) OUT: "85733AMECH_PP_2012_0F" hhdinhin@HH700103PC
9:14:43 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyschrju@wy021777pc
9:14:52 (adskflex) OUT: "64400AMECH_PP_F" wystocso@WY020858PC
9:14:52 (adskflex) OUT: "85733AMECH_PP_2012_0F" wystocso@WY020858PC
9:14:57 (adskflex) OUT: "59200AMECH_PP_2009_0F" wykatzmi@wy020333pc
9:15:03 (adskflex) OUT: "64400AMECH_PP_F" brhatizu@BR024958PC
9:15:03 (adskflex) OUT: "85733AMECH_PP_2012_0F" brhatizu@BR024958PC
9:15:04 (adskflex) OUT: "64400AMECH_PP_F" simuslmu@SI024009NB
9:15:04 (adskflex) OUT: "85733AMECH_PP_2012_0F" simuslmu@SI024009NB
9:15:12 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb
9:15:15 (adskflex) OUT: "64400AMECH_PP_F" wistauma@WI025123NB
9:15:15 (adskflex) OUT: "85733AMECH_PP_2012_0F" wistauma@WI025123NB
9:15:17 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyriegma@wy021781pc
9:15:27 (adskflex) OUT: "59200AMECH_PP_2009_0F" wydreith@wy020286pc
9:15:29 (adskflex) OUT: "59200AMECH_PP_2009_0F" wytascbr@wy021783pc
9:15:35 (adskflex) OUT: "64400AMECH_PP_F" klwoltma@KL024306PC
9:15:35 (adskflex) OUT: "85733AMECH_PP_2012_0F" klwoltma@KL024306PC
9:15:53 (adskflex) OUT: "64400AMECH_PP_F" wylaenno@WY025050PC
9:15:53 (adskflex) OUT: "85733AMECH_PP_2012_0F" wylaenno@WY025050PC
9:16:06 (adskflex) OUT: "64400AMECH_PP_F" bkpanalo@BK024806PC
9:16:06 (adskflex) OUT: "85733AMECH_PP_2012_0F" bkpanalo@BK024806PC
9:16:30 (adskflex) OUT: "59200AMECH_PP_2009_0F" wypoecml@wy470034pc
9:16:46 (adskflex) OUT: "64400AMECH_PP_F" sbscholu@SB024478PC
9:16:46 (adskflex) OUT: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:17:54 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:17:54 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC
9:18:42 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyschrju@wy021777pc
9:19:09 (adskflex) OUT: "64400AMECH_PP_F" sbscholu@SB024478PC
9:19:09 (adskflex) OUT: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:19:49 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:19:49 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC
9:20:10 (adskflex) IN: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb
Server status:
Users of 64400AMECH_PP_F: (Total of 39 licenses issued; Total of 19 licenses in use)
"64400AMECH_PP_F" v1.000, vendor: adskflex
floating license
bkpanalo BK024806PC BK024806PC (v1.000) (WYACLICWN/27001 3601), start Wed 7/31 9:16
brhatizu BR024958PC BR024958PC (v1.000) (WYACLICWN/27001 2201), start Wed 7/31 9:15
hhdinhin HH700103PC HH700103PC (v1.000) (WYACLICWN/27001 1601), start Wed 7/31 9:14
klwoltma KL024306PC KL024306PC (v1.000) (WYACLICWN/27001 3201), start Wed 7/31 9:15
mogoncal MO520207PC MO520207PC (v1.000) (WYACLICWN/27001 4201), start Wed 7/31 9:27
mokulbok MO520221PC MO520221PC (v1.000) (WYACLICWN/27001 1101), start Wed 7/31 9:14
sfaspaas SF021293NB SF021293NB (v1.000) (WYACLICWN/27001 201), start Wed 7/31 9:13 (linger: 15486300)
simuslmu SI024009NB SI024009NB (v1.000) (WYACLICWN/27001 2401), start Wed 7/31 9:15
stkrafru ST024494NB ST024494NB (v1.000) (WYACLICWN/27001 901), start Wed 7/31 9:13 (linger: 120360)
wistauma WI025123NB WI025123NB (v1.000) (WYACLICWN/27001 601), start Wed 7/31 9:13 (linger: 1847640)
wyfieska WY024728NB WY024728NB (v1.000) (WYACLICWN/27001 4701), start Wed 7/31 9:30
wykrenma WY021784PC WY021784PC (v1.000) (WYACLICWN/27001 1502), start Wed 7/31 9:27
wylaenno WY025050PC WY025050PC (v1.000) (WYACLICWN/27001 3401), start Wed 7/31 9:15
wymurawo WY021850NB WY021850NB (v1.000) (WYACLICWN/27001 4004), start Wed 7/31 9:28
wypilsmi WY025240PC WY025240PC (v1.000) (WYACLICWN/27001 101), start Wed 7/31 9:13 (linger: 15520260)
wyriglth WY024048PC WY024048PC (v1.000) (WYACLICWN/27001 1301), start Wed 7/31 9:14
wystocso WY020858PC WY020858PC (v1.000) (WYACLICWN/27001 1901), start Wed 7/31 9:14
wywallmi WY024047PC WY024047PC (v1.000) (WYACLICWN/27001 501), start Wed 7/31 9:13 (linger: 1939500)
Users of 85733AMECH_PP_2012_0F: (Total of 39 licenses issued; Total of 16 licenses in use)
"85733AMECH_PP_2012_0F" v1.000, vendor: adskflex
floating license
bkpanalo BK024806PC BK024806PC (v1.0) (WYACLICWN/27001 3701), start Wed 7/31 9:16
brhatizu BR024958PC BR024958PC (v1.0) (WYACLICWN/27001 2301), start Wed 7/31 9:15
hhdinhin HH700103PC HH700103PC (v1.0) (WYACLICWN/27001 1701), start Wed 7/31 9:14
klwoltma KL024306PC KL024306PC (v1.0) (WYACLICWN/27001 3301), start Wed 7/31 9:15
mogoncal MO520207PC MO520207PC (v1.0) (WYACLICWN/27001 4301), start Wed 7/31 9:27
mokulbok MO520221PC MO520221PC (v1.0) (WYACLICWN/27001 1201), start Wed 7/31 9:14
simuslmu SI024009NB SI024009NB (v1.0) (WYACLICWN/27001 2501), start Wed 7/31 9:15
stkrafru ST024494NB ST024494NB (v1.0) (WYACLICWN/27001 801), start Wed 7/31 9:13 (linger: 120360)
wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 2801), start Wed 7/31 9:15
wyfieska WY024728NB WY024728NB (v1.0) (WYACLICWN/27001 4801), start Wed 7/31 9:30
wykrenma WY021784PC WY021784PC (v1.0) (WYACLICWN/27001 4102), start Wed 7/31 9:27
wylaenno WY025050PC WY025050PC (v1.0) (WYACLICWN/27001 3501), start Wed 7/31 9:15
wymurawo WY021850NB WY021850NB (v1.0) (WYACLICWN/27001 4601), start Wed 7/31 9:28
wyriglth WY024048PC WY024048PC (v1.0) (WYACLICWN/27001 1401), start Wed 7/31 9:14
wystocso WY020858PC WY020858PC (v1.0) (WYACLICWN/27001 2001), start Wed 7/31 9:14
wywallmi WY024047PC WY024047PC (v1.0) (WYACLICWN/27001 401), start Wed 7/31 9:13 (linger: 1939500)
Mit freundlichen Grüßen / Kind regards
Martin Stauch
Applicationmanager CAD/Presenter - IT Salessupport
BENE AG A-1010 Wien Neutorgasse 4-8
Telefon +43-1-53426-1310 Fax +43-1-53426-991310 Mobil +43-676-81511310
mailto:martin.stauch@bene.com www.bene.com
Firma: BENE AG Rechtsform: Aktiengesellschaft Sitz: Waidhofen/Ybbs
Firmenbuchnummer: 89102 h Firmenbuchgericht: Landesgericht St. Pölten
Dear Travis!
We have also other products, should I upload our lic file here for you?
Best regards
Martin Stauch
You can copy it into a PM to me if you wish. Since you have multiple products, I think I have a clever way for you to clear your stuck licenses.
Travis and Martin,
This EXACT thing happened to me, if I am understanding correctly. Every time I restart my license server, THREE of our users get assigned borrowed licenses lasting about 180 days. This happens regardless of whether these users are even working in AutoCAD at the time of the server restart. It also happens even though my options file limits license borrowing to 16 days. Also, the borrow expiration day then as reported by the server is different than the borrow expiration date as reported by the AutoCAD installation on the individual PC.
I hope the "clever way" you mentioned, Travis, would apply to my case.
Please advise.
Thank you.
Jamie
If your licenses are being borrowed for longer than your options file allows, then you probably have a typo in your options file.
