Installation & Licensing
Active Member
orenofer
Message 1 of 15 (919 Views)
cannot find network license manager
919 Views, 14 Replies
06-25-2013 04:44 AM
HI,
I'm trying to setup inventor pro 2014 with a network license manager.
I've followed the instructions and LMTOOLS acknowledges that the server is UP.
I've down this twice: once on a dedicated network license manager and one on my own computer where i have installed the inventor. In either cases, I receive the same problem:
When i start inventor it prompts me to either a license file or the license manager computer host name. Neither work: After several times, of inputing the host name, or giving the license file, I receive "A valid license could not be obtained by the network license manager" error [-1.359.2]
I tried opening port 2080 on the windows firewall. no change.
Please advice.
DarrenP
Message 2 of 15 (911 Views)
Re: cannot find network license manager
06-25-2013 06:09 AM in reply to: orenofer
can you ping the license server by hostname?
DarrenP
Message 3 of 15 (909 Views)
06-25-2013 06:12 AM in reply to: DarrenP
The FLEXlm® based version uses the following ports:
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
you also have to allow these ports through the firewall
Active Member
orenofer
Message 4 of 15 (903 Views)
06-25-2013 06:41 AM in reply to: DarrenP
yes. no problem there.
DarrenP
Message 5 of 15 (900 Views)
06-25-2013 06:45 AM in reply to: orenofer
Please advice.
what if you use the Ip address instead?
then does inventor find a license
Active Member
orenofer
Message 6 of 15 (899 Views)
06-25-2013 06:47 AM in reply to: DarrenP
I've opened these ports. no change ;-( .
"A valid license could not be obtained by the network license manager." Error [-15.570.0]
Active Member
orenofer
Message 7 of 15 (894 Views)
06-25-2013 06:49 AM in reply to: DarrenP
nop. by using directly the IP doesn't help either. as well as 127.0.0.1 , localhost ..
Darin.Green
Message 8 of 15 (891 Views)
06-25-2013 06:57 AM in reply to: orenofer
Can you post the log file for the license manager?
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Active Member
orenofer
Message 9 of 15 (884 Views)
06-25-2013 07:29 AM in reply to: Darin.Green
Here attached.
Darin.Green
Message 10 of 15 (871 Views)
06-25-2013 08:47 AM in reply to: orenofer
Is the License Manager and Inventor installed on the same machine? If so, try to completely disable the firewall and check the following registry key:
HKEY_CURRENT_USER\Software\FLEXlm License Manager
There should be a file named "ADSKFLEX_LICENSE_FILE" with a long string to the licpath.lic file.
Clear the value field and enter "@servername;@server IP address" <-- replace the text after each @ symbol with the correct information then try to start the application.
Darin Green
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
