Installation & Licensing
can't find license
14 REPLIES 14
Message 1 of 15
jdcho
14497 Views, 14 Replies
can't find license
Hopefully someone has an answer for this .... I'm running the latest licenser manager with 9 licenses for revit 2011.  Every now and then a machine (the first one in the morning to boot up revit) will say A VALID LICENSE CANNOT BE OBTAINED FROM THE NETWORK LICENSE MANAGER.  I'll then reboot the server and everything is fine and everybody can get on and work.  This is hit or miss, every couple of days, every couple of weeks.
14 REPLIES 14
Message 2 of 15
TravisNave
in reply to: jdcho
Was there an error number associated with this message?  The error number helps identify the problem.  However, it's probably due to network latency.  If you add a system environment variable called FLEXLM_TIMEOUT and give it a value of 1000000 it may resolve your issue.
For more detailed information, see this KB:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13744786&linkID=9243099
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 15
frhervet
in reply to: jdcho
Next time you have the problem, Do a "Perform satus enquiry" on the server and give us the log file to see where can be the problem.
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
Message 4 of 15
jdcho
in reply to: jdcho
OK so it happened again .... a user got a message dialogue box saying Your application was not able to obtain a license because the FLEXnet license server manager cuold not determine where to find the licensing data it needs.   and then A valid license couldn not be obtained by the network license manager Error [-15.10.10061]
The only thing that worked was to reboot the server, but I can't reboot the server everytime someone can't find the license.  I'm attaching the status enquiry file and the debug log.
Message 5 of 15
DarrenP
in reply to: jdcho
how many users does this happen to?
did you try the above suggestion?
DarrenP
Message 6 of 15
jdcho
in reply to: jdcho
Yes, tried the above suggestions .. but those suggestion don't really apply except for the one that says to rename the cascade file.
Message 7 of 15
frhervet
in reply to: jdcho
Have you both product on each pc ?
Franck Hervet
Message 8 of 15
jdcho
in reply to: jdcho
both as in autocad revit and another autocad product ?  that would be yes, we're running both autocad revit 2011 and autocad architecture 2011.
Message 9 of 15
jdcho
in reply to: jdcho
can the highlighted portion below be something ??
adskflex: Cannot read data from license server system.
The license server system appears to be running, but is not
responding If this persists, notify the System Administrator.
(The license server manager (lmgrd) and vendor daemon processes
should be terminated and restarted.)
Hostname:      CBLH-SERVER01
License path:  27000@CBLH-SERVER01;
FLEXnet Licensing error:-16,287
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
Message 10 of 15
TravisNave
in reply to: jdcho
Yes.  Stop the license server.  Then close LMTOOLS.  Open the Task Manager and make sure that adksflex.exe and lmgrd.exe are all terminated.  Then relaunch LMTOOLS and restart the service.  Check the status to ensure that all errors are gone.  If not, repost results here.
Autodesk Forums:
Message 11 of 15
frhervet
in reply to: jdcho
See also this :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7236859&linkID=9240617
Franck Hervet
Message 12 of 15
jdcho
in reply to: frhervet
nope, the lenght is only 68 characters long .. and haven't tried closing out of lmtools yet ...
Message 13 of 15
jdcho
in reply to: jdcho
this was a vpn issue .. when ever anybody used the vpn it did something to the network license.  we moved the license manger to a different server.
Message 14 of 15
dgussman
in reply to: jdcho
I have the same problem with a few users that we are allowing to connect via VPN to use the network license server.  Everything was working fine for a few months and all of a sudden, the errors stated to popup sporadically.  I understand you fixed the problem but I fail to see the realtion between the VPN connection and the server.
For me, I have my VPN users hit my Cisco device first and then connect to the license server.  Please help.
Message 15 of 15
jdcho
in reply to: dgussman
been on vacation so sorry for the late reply. I'm not an IT person just someone who was pushed into it, so I'm not sure what really happens with the vpn, license manager and such. all I know is that once we moved the license manager to a different server, the problems went away. also, one thing that I had to do was make a new environmental variable for the user (flexlm timeout) ...... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-A... hope that helps.
Administrator Productivity
