• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Accepted Solution
    can't find license
    1902 Views, 12 Replies
    02-11-2011 07:21 AM
    Hopefully someone has an answer for this .... I'm running the latest licenser manager with 9 licenses for revit 2011.  Every now and then a machine (the first one in the morning to boot up revit) will say A VALID LICENSE CANNOT BE OBTAINED FROM THE NETWORK LICENSE MANAGER.  I'll then reboot the server and everything is fine and everybody can get on and work.  This is hit or miss, every couple of days, every couple of weeks.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: can't find license
    02-11-2011 07:44 AM in reply to: jdukc
    Was there an error number associated with this message?  The error number helps identify the problem.  However, it's probably due to network latency.  If you add a system environment variable called FLEXLM_TIMEOUT and give it a value of 1000000 it may resolve your issue.
    For more detailed information, see this KB:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13744786&linkID=9243099
    Valued Mentor
    Re : can't find license
    02-11-2011 09:36 AM in reply to: jdukc
    Next time you have the problem, Do a "Perform satus enquiry" on the server and give us the log file to see where can be the problem.
    Franck Hervet
    S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
    02-17-2011 06:36 AM in reply to: jdukc
    OK so it happened again .... a user got a message dialogue box saying Your application was not able to obtain a license because the FLEXnet license server manager cuold not determine where to find the licensing data it needs.   and then A valid license couldn not be obtained by the network license manager Error [-15.10.10061]
    The only thing that worked was to reboot the server, but I can't reboot the server everytime someone can't find the license.  I'm attaching the status enquiry file and the debug log.
    *Expert Elite*
    DarrenP
    02-17-2011 06:46 AM in reply to: jdukc
    how many users does this happen to?
    did you try the above suggestion?
    02-17-2011 08:35 AM in reply to: jdukc
    Yes, tried the above suggestions .. but those suggestion don't really apply except for the one that says to rename the cascade file.
    Valued Mentor
    02-17-2011 08:55 AM in reply to: jdukc
    Have you both product on each pc ?
    Franck Hervet
    02-17-2011 10:20 AM in reply to: jdukc
    both as in autocad revit and another autocad product ?  that would be yes, we're running both autocad revit 2011 and autocad architecture 2011.
    02-17-2011 11:09 AM in reply to: jdukc
    can the highlighted portion below be something ??
    adskflex: Cannot read data from license server system.
    The license server system appears to be running, but is not
    responding If this persists, notify the System Administrator.
    (The license server manager (lmgrd) and vendor daemon processes
    should be terminated and restarted.)
    Hostname:      CBLH-SERVER01
    License path:  27000@CBLH-SERVER01;
    FLEXnet Licensing error:-16,287
    For further information, refer to the FLEXnet Licensing documentation,
    available at "www.acresso.com".
    *Expert Elite*
    TravisNave
    02-17-2011 11:51 AM in reply to: jdukc
    Yes.  Stop the license server.  Then close LMTOOLS.  Open the Task Manager and make sure that adksflex.exe and lmgrd.exe are all terminated.  Then relaunch LMTOOLS and restart the service.  Check the status to ensure that all errors are gone.  If not, repost results here.
