• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    AJAMP
    can't find file error message
    340 Views, 6 Replies
    10-19-2012 08:16 AM
    After initial boot up of my Windows XP system, if I try to open an AutoCAD LT 2013 file by double clicking directly on the file name I will get AutoCAD 2013 to go through its initial startup routine and get the following error message telling me the file can't be found and to double check the spelling etc.  I can then re-click on the file name and it opens right up.  If I close the AutoCAD 2013 application and go through the same routine it opens properly.  This is probably a Windows issue but I'm not sure it's not an autoCAD startup issue either.  Any ideas or help would be great.
    Mark
    Please use plain text.
    TravisNave
    Re: can't find file error message
    10-19-2012 08:44 AM in reply to: AJAMP
    Probably a latency issue with loading a drawing over the network.  You can either work on the drawing locally from your C:\ drive or open your Autodesk program first and File > Open the .dwg.  Working over a mapped network drive is usually not the most efficient method.  It's one of the reasons for Vault.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    AJAMP
    10-19-2012 08:59 AM in reply to: TravisNave
    Just for my clarification... The latency is in that the open command is trying to access the file from the network drive on initial startup before the application is actually ready to load it?  Since I don't experience this 'error' once I've had AutoCAD open I'm assuming that there are some system commands that are going on during initial startup that are more involved than they were with AutoCAD 2012 and earlier versions.  Is that correct? and the answer is if everyone upgrades to 2013 we'll just have to deal with the error message unless we also invest in Vault?
    Mark
    TravisNave
    10-19-2012 09:05 AM in reply to: AJAMP
    Check the properties of your launch icon and see if it is set to launch some particular dwg.  Seems rather odd to me.
    Travis Nave
    Active Member
    AJAMP
    11-15-2012 12:58 PM in reply to: TravisNave
    Still have the error message, and no one from Autodesk is responding?  It only happens during "First run initializing".  It would seem to be a bug.  And it's definitely bugging me.  I find it hard to believe that no one else experiences this.
    TravisNave
    11-15-2012 01:12 PM in reply to: AJAMP
    If it were widespread, I think there'd be an epidemic on the boards.
    Travis Nave
    Active Member
    AJAMP
    11-21-2012 08:50 AM in reply to: TravisNave
    Still not resolved.  Does anyone know what is happening during the "First run initializing..." phase of the program startup versus "initializing..." program startup that happens during subsequent application starts.
    Whatever is happening during the "First run initializing..." phase seems to be where the problem lies.  People have suggested a latency problem due to accessing a networked/mapped drive. But as I've stated, the same thing happens if I  attempt to open the application by double clicking a file from my desktop or C:// drive or the network drive if it is the 1st time I've tried opening AutoCAD since booting my system up.  If I open the application first and then once it's open, open the same file - no problem.  Also, if I've closed AutoCAD and later go back and double click to open a file from anywhere there is no error message (note AutoCAD does not say "First run initializing..." during the startup now).  Also, this problem did not exist on the same machine until I upgraded to AutoCAD LT 2013 from AutoCAD LT 2012.  That's why I believe it to be a bug in the startup process in the new version of AutoCAD LT 2013.
