Installation & Licensing
can't activation revit architecture 2013
2 REPLIES 2
5650 Views, 2 Replies
Hi every body
I'm really need help in activation Autodesk revit architecture 2013, I have an activation code but every time I still have the same error when I entired the activation code
Registration-Activation Error (0015.111)
This is the error I found...
I'm waiting for your response
2 REPLIES 2
TravisNave
in reply to: 200808897
Welcome to the community.  Did you get the activation code for this product's request code, or are you using an activation code from a previous activation and/or another computer?
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Good Luck!
Autodesk Forums:
philip.s
Hello!
As it doesn't look like you're using a valid serial number, not sure that we can do much here to assist with the activation.
Here are our purchase options just in case you're interested 🙂
Administrator Productivity
