Installation & Licensing
New Member
Message 1 of 8 (996 Views)
can't activate educational version 3Dsmax
996 Views, 7 Replies
03-05-2013 05:49 AM
It's been a while I've tried everything to activate my educational version of 3Dsmax.
The thing is that when I click en activate, I'm suppose to have a window pop up ith two choices ( manually activation and so on) right?  BUT it seems that this window won't completely upload. I have a white page with two ticking boxes and no information or possibility to confirm anything.
I've tried to uninstall and repare but doesn't help, the problem persists.
what am I suppose to do ?
Thank you for you answers! :smileyhappy:
BRIGLIA Helene
PS: oh and when I start up the software, the Autodesk licensing window is all white ! : /
camilo.lemos
Message 2 of 8 (993 Views)
Re: can't activate educational version 3Dsmax
03-05-2013 06:04 AM in reply to: helene.briglia
Hi helene.briglia and welcome to our community:smileyhappy:
You can find steps on how to fix the Blank Activation Screen issue here.
Camilo Lemos
New Member
Message 3 of 8 (833 Views)
03-19-2013 02:08 PM in reply to: camilo.lemos
Hello!
I' ve been searching a while for my activation problem (wich is also the white screen) and I' ve already tryed all of your solutions (6 solutions: internet explorer 9, Activex, command prompt, etc,...) but none of them are working on my pc.
I really don' t know what to do now, I only have 2 days trial anymore...
Can you fix my problem?
Kind regards,
Jonathan
philip.s
Message 4 of 8 (825 Views)
03-19-2013 03:18 PM in reply to: jonathan05
Hello Jonathan,
What OS are you running? Can you please repeat step 3 and let us know if that resolves the issue?
3.  Manually register the Jscript.dll and VBscript.dll files
If the previous steps do not work, you may need to manually register the Jscript.dll and Vbscript.dll files.
  1. Open the Windows Command Prompt.
  2. At the command prompt, navigate to one of the following folders:
    On the 32-bit version of Vista/Win7
     C:\Windows\System32
    On the 64-bit version of Vista/Win7
    C:\Windows\SysWow64
  3. At the command prompt, enter regsvr32 jscript.dll
  4. At the command prompt, enter regsvr32 vbscript.dll
Philip Schmelzer
Active Member
Message 5 of 8 (811 Views)
03-19-2013 04:51 PM in reply to: helene.briglia
Helene.briglia,
If I may ask, which solution ended up fixing your problem? I'm having the same exact issue and nothing is working for me.
Also, which version of windows do you have?
Thanks!
New Member
Message 6 of 8 (794 Views)
03-20-2013 08:13 AM in reply to: helene.briglia
I use Windows 7 as OS- system.
I already tried step 3. There is no problem with entering regsvr32 vbscript.dll but the regsvr32 jscript.dll doesn' t work.
I used a program called "FixCleaner" that repairs some files, but It also didn' t work.
New Member
Message 7 of 8 (781 Views)
03-20-2013 10:31 AM in reply to: jonathan05
Well to tell the truth I haven't managed to activate it.
I thought that the topic of Autodesk about the white screen was going to be the solution.
I tried out each one of the different propositions and none worked.
I am on Window 7.
I decided to try and find other solutions since then, and still nothing.
Active Member
Message 8 of 8 (758 Views)
03-21-2013 11:24 AM in reply to: helene.briglia
I'm in the same boat as you helene.briglia.
I've gotten into contact with Autodesk support via e-mail, but they aren't seeming to understand my situation
I wonder if there is a way to activate and use the product without even having to use the licensing windows. That way we don't even need to worry about the blank activation windows that are giving us issues!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
