Installation & Licensing
can't activate autocad 2014(student version)
22 REPLIES 22
Message 1 of 23
041314855
10540 Views, 22 Replies
I downloaded autocad 2014, and for some reason I can't activate it.
An error appears trying to find the license.
It took me so long to download this huge program file and now I can't even open it. Very frustrating....
22 REPLIES 22
Message 2 of 23
pendean
in reply to: 041314855
During what exact step/phase of installation did the error occur?
CDan you post a screenshot of the error message?
Message 3 of 23
TravisNave
Welcome to the community.
Many people are experiencing this issue.  You might check this KB about the 2014 activation crash and see if it applies to your issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
Good Luck!
Autodesk Forums:
Message 4 of 23
041314855
It happens while checking the license. A box appears that says " Please wait while your license is being verified." Then another box appears saying that the program has to be stopped due to a probem.
Message 5 of 23
philip.s
Hello Geena,
Some users have had success turning off their antivirus software to get past the checking license freeze / crash. Can you please give that a shot and let us know how it goes?
Message 6 of 23
041314855
I tried turning off antivirus software, and I still can't get the problem solved. Seems like it is something else...
Message 7 of 23
s080068
Did you find a solution yet?
I'm experiencing the exact same problem only with Revit 2014.
Message 8 of 23
s080068
in reply to: s080068
However I have had no problems with installing and running Robot 2014
Message 9 of 23
s080068
I just installed a 30-day trial version of Revit 2014, however this changed nothing, the program still crashes when launched even though it isn't trying to verify the license no more. So could it be that the problem isn't the license?
Message 10 of 23
in reply to: philip.s
Hello! I am facing this problem as well. Downloaded AutoCad 2014 (student version) and cannot put in my license numbers, since it stays like this (as in the picture above) and doesn't change. Is there any other way to work out license?
Message 11 of 23
byron.morales
Hello Margea,
Please try the following. Close all programs then:
1. Rename the following file by adding a .bak extension at the end of the filename.
   Windows XP    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
   Vista/Windows 7
   C:\ProgramData\FLEXnet\adskflex_*_tsf.data
(note this is a hidden file and you might need to enable show hidden files under folder options)
This file contains all activations for all 2010 and newer Autodesk products.  You will need to re-register all your products if this file is renamed/deleted.
2. Restart AutoCAD and it will automatically re-register via Register Today and it will start up as expected.   A new adskflex_*_tsf.data file will be created when you re-register your product.
If you are prompted for manual activation please contact usat 1-800-551-1490 press 1 for English and press 1 again for StandAlone.
If the issue persist after performing the above steps please review the following knowledge base article poreviosuly shared by Travis on an earlier post Reply:
Let us know the results.
Byron M.
Message 12 of 23
dembkod
margea370,
Hello. Your blank screen is likely a result of having Internet Explorer 10 installed. Uninstall it.
  1. In the Windows Control Panel, go to Programs and Features
  2. Click Turn Windows features on or off
  3. Uncheck the Internet Explorer 10 box and click "OK". Let the process run
  4. After the system finishes processing, reboot the machine
  5. In the Windows Control Panel, go to Programs and Features
  6. Click "View Installed Updates"
  7. Locate the update for Internet Explorer 10 and select it and click "Uninstall" at the top of the screen.
  8. Let the process complete and reboot.
Thank you for taking part in our community!
David Dembkoski
Message 13 of 23
in reply to: byron.morales
Thank you for information Byron,
I checked for C:\ProgramData\FLEXnet\adskflex_*_tsf.data and could not find this exact file. How should I re-register my products?
Message 14 of 23
in reply to: dembkod
Thank you David!
Autocad activated itself and everything works well now!
Message 15 of 23
I tried to do as suggested, but there is no "FLEXnet\adskflex_*_tsf.data" in the folder C\ProgramData.
I am using Windows 7.
Do you have any other suggestions?
Message 16 of 23
goutham149
i am facing the same problem what to do
Message 17 of 23
glenobie
in reply to: goutham149
Tried all posted solutions with no effect.
Message 18 of 23
glenobie
in reply to: glenobie
BTW, I'm trying to get the licensing window on the screen for 3ds Max. I get the serial number window, and I get it to send me an activation code, but I never get a window for entering the activation code. Instead, I just get the serial number window to pop up again.
Message 19 of 23
joane.bonghanoy
Glen,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and a screenshot of the error so I can check on my end.
Joane Bonghanoy
Message 20 of 23
hi. i have the same issue i cant activate my autocad licesne it gives me a blank screen or two buttons. i unistalled internet explorer and i also unistalled autocad altogether and downloaded it again. still nothing. please help
Administrator Productivity
