Installation & Licensing
can't activate 3Ds Max on second PC
1 REPLY 1
382 Views, 1 Reply
hi,
I had 3D max on 2 pc at home which was the maximum. my laptop was crashed and i had to install another windows. now i try to activate 3Ds max but  it gives an messege and says that i have used the maximum limit of activation. i don't know what to do.
thanks
1 REPLY 1
TravisNave
You can use the online method to activate your license here:
http://knowledge.autodesk.com/installation-and-licensing
You will need a manual activation code at this point.
Autodesk Forums:
Administrator Productivity
