Installation & Licensing
can not install Revit2013
2 REPLIES 2
Moshe-A
284 Views, 2 Replies
Hi Guys,
i have installed Revit2014 (& AutoCAD 2014) on a win7/64 - 8gb machine
the user on his current project still need to work on Revit2013
i did try to install revit2013,  setup starts but stuck there (initializing....)
Net Framework 4.5 is installed
what could be the reason?
thanks in advance
Moshe
2 REPLIES 2
david.lau
in reply to: Moshe-A
It could be Autodesk 360/Sync or .NET.  I would remove them from the control panel and try the install again.
David Lau
Moshe-A
in reply to: david.lau
David hi,
it was a deplyment installation so there was a need to adjust the depoly setup and it worked.
thank you very much
Moshe
Administrator Productivity
