I am having troble installing Inventor 2012 Product design suite Premium on my new dell Precision T3500 64bit computer.
As soon as installation starts it stops and says "Microsoft VB C++ Redestibutable (86).
Installation complete.
Nothing at all installed, this occurs within 20 seconds.
What do I need to do to get the product to install??
Solved by WILLIAMF. Go to Solution.
Firstly, I would update your computer with the latest service pack "Microsoft Windows 7 SP1" and then perform a "Microsft Update" to grab all the latest updates.
Jon
If you try to install the file it fails on, it says that a newer version is already installed. Autodesk didn't put in a check to see if a newer version is installed.
Good Luck!
It worked perfectly by uninstalling MS C++ 2010 (86). All products loaded.
I found this on another post.
William,
In case you get roadblocked by the next error, here's a link to the fix that worked for me>
http://forums.autodesk.com/t5/Installation-Licensing/Installation-Problems/td-p/3343703
Tere's a PDF I made with all the screenshots to try to make it easy to follow. Hope you don't need it.
BASICS
1> Make SURE you are logged in as an Administrator (see AM an Administrator.jpg)
2> Any MS Visual C++ version NEWER than 10.0.0309 have to be Uninstalled
3> A new folder has to be created and Permissions given to SYSTEM
Best of luck
I'll print this stuff out just in case but I think we are good now.
