I recieved our 2012 design suite media as a USN stick. I tried both the following: copy the media to my disk a mak a peployment and directly from the USB stick. I get this error each time:
How should I run the deployment?
Joe Bouza
i know there are problems creating a deployment on windows 7/vista 64 bit: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16800261&linkID=9240657&CMP=OTC-RSS...
DarrenP
or you can try this: http://upandready.typepad.com/up_and_ready/2011/07/autodesk-suites-failure-creating-deployment-for-a...
if you don't have access to windows xp
DarrenP
i ran into this issue to when trying to create the deployment from a vista 64 bit machine i had to physically go to the server which is server 2003 r2 sp2 64 bit and create the deployment from there and it worked fine
DarrenP
