Installation & Licensing
building design suite 2013- windows 8
7 REPLIES 7
Message 1 of 8
1872 Views, 7 Replies
can i install building design suite 2013 on windows 8?
7 REPLIES 7
Message 2 of 8
emily.xu
Currently, we don't support BDS running on Windows 8 offically. You can check the system requirement here.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Message 3 of 8
arlinpega.bibat
Hi robertjamesblevins:
I have here a link to system requirements for Building Design Suite. It didn't mention Windows 8, but you can try. However, we cannot guarantee that it will function properly. This is why we have specifically listed the requirements to which the product is compatible with.
Best Regards,
Arlin Bibat
Message 4 of 8
TravisNave
It'll likely fail to install due to .NET Framework, being that v4.5 is pre-installed with Windows 8.  You'll have to do some modifying of the setup.ini installation files to get the product suite installed on there in Windows 7 compatibility mode, as Administrator.  It can be done, but it is not supported at this time.
Autodesk Forums:
Message 5 of 8
in reply to: arlinpega.bibat
i did a win 8 upgrade on my laptop with inventor pro 12 and it works, i dont like win 8. glad i dident put it on my BDS 13 machine.
Message 6 of 8
hi ,
its mid January 2013 , has Autodesk already sorted out this issue about non compatibility of the Austodesk Building Design Suite 2013 premium and installation -run on Windows 8 ???
Most computers on the market are carrying windows 8 .
Please need  update from Autodesk support ,please answer yes or no , work so so is not an answer for such an expensive software.
On your answer I will decide which laptop to buy .
Thanks in advance for help.
Message 7 of 8
DarrenP
no
read this page: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
they probably won't support it until the next release
DarrenP
Message 8 of 8
in reply to: DarrenP
thanks for your quick reply.
Administrator Productivity
