• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    building design suite 2013- windows 8
    882 Views, 7 Replies
    10-30-2012 07:37 PM
    can i install building design suite 2013 on windows 8?
    Please use plain text.
    Product Support
    emily.xu
    Re: building design suite 2013- windows 8
    10-30-2012 08:59 PM in reply to: robertjamesblevins
    Currently, we don't support BDS running on Windows 8 offically. You can check the system requirement here.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Emily Xu
    AutodeskCare | Product Support
    Autodesk, Inc.
    Customer Service
    arlinpega.bibat
    10-30-2012 09:40 PM in reply to: robertjamesblevins
    Hi robertjamesblevins:
    I have here a link to system requirements for Building Design Suite. It didn't mention Windows 8, but you can try. However, we cannot guarantee that it will function properly. This is why we have specifically listed the requirements to which the product is compatible with.
    Best Regards,
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    *Expert Elite*
    TravisNave
    10-31-2012 06:53 AM in reply to: robertjamesblevins
    It'll likely fail to install due to .NET Framework, being that v4.5 is pre-installed with Windows 8.  You'll have to do some modifying of the setup.ini installation files to get the product suite installed on there in Windows 7 compatibility mode, as Administrator.  It can be done, but it is not supported at this time.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    12-31-2012 08:09 AM in reply to: arlinpega.bibat
    i did a win 8 upgrade on my laptop with inventor pro 12 and it works, i dont like win 8. glad i dident put it on my BDS 13 machine.
    New Member
    01-15-2013 01:39 AM in reply to: robertjamesblevins
    hi ,
    its mid January 2013 , has Autodesk already sorted out this issue about non compatibility of the Austodesk Building Design Suite 2013 premium and installation -run on Windows 8 ???
    Most computers on the market are carrying windows 8 .
    Please need  update from Autodesk support ,please answer yes or no , work so so is not an answer for such an expensive software.
    On your answer I will decide which laptop to buy .
    Thanks in advance for help.
    *Expert Elite*
    DarrenP
    01-15-2013 05:42 AM in reply to: willarch
    no
    read this page: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
    they probably won't support it until the next release
    New Member
    01-15-2013 09:06 AM in reply to: DarrenP
    thanks for your quick reply.
