Installation & Licensing
cartoonkeyur
344 Views, 1 Reply
blank window
hey i am using 3d max software as a trial version.
i hav the serial no. for the registered version, but the activation window of 3d max where we paste the no. is coming blank.
so i am not able to activate my software.
can anyone tell me how do i fix this problem?
Tags (1)
1 REPLY 1
TravisNave
in reply to: cartoonkeyur
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Autodesk Forums:
Administrator Productivity
