hi
iam trying to activate 3ds max 2010 but all i get is blank activation screen with tow radio buttons
how can i fix this problem?
thank u
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
thank you
But i do not use explolrer i use firefox or google
and i need it to max 2010 not autocad
the secound link didnt help much i was trying it before i post my question
why so many ppl get this problem anyway?
can someone help me pl ?
thank u
There's a lot of information in that second link.
Hi dayanfrida:
Please send us your serial number through private message together with your contact information (email add, address and phone number). We research on your issue further and give you a call if needed to assist you with your concern.
Arlin
Hi dayanfrida:
Please send it through private message, the envelope next to your account name at the top of this page.
Arlin
hi
So finally i gota non blank screen but i got this window after i put the activation code
can anyone knows what that means and how can i fix it?
thank u
Click Yes. Might consider turning off script debugging in your browser advanced settings. Make sure you have local admin rights on your machine.
Hi dayanfrida:
I have responded to your private message. Should you require any activation issue, you may go to www.autodesk.com/licensesupport and our Registration and Activation team would be able to assist you further.
Thank you!
Best Regards,
Arlin
** If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
