hi,
i just tried to install this following update
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804875&linkID=9242019
everything runs fine. but when i checked "view installed updates" in window 7 control panel. i dont see it. anyone knows why? i can see other updates which i installed before thru.
thanks a lot
It's possible that they simply did not add the code to the registry for the hotfix to appear in Control Panel. If it installed correctly, you should be good to go.
