tried three different downloads.
tried 4 installations.
attached is the instalation log.
hope you can help, looks like something to do with c++
Hi reeveseng,
There may be a newer version of the Microsoft Visual C++ 2010 Redistributable Package installed on your computer which is causing the install failure.
A typical workaround is to uinstall Microsoft Visual C++ 2010 Redistributable (x86) via the Control Panel (add / remove programs), reinstall the software, and then install the latest version of Microsoft Visual C++ 2010 Redistributable (x86) from Microsoft (linked here).
For additional 1603 error causes and corresponding solutions, click here.
Please accept as a solution if this fully resolves the issue, or reply with specifics if the problem still persists.
