• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    autodesk failing to install
    179 Views, 6 Replies
    04-25-2012 04:58 AM
    I tride to install Autodesk_Inventor_2012_English_Win_64bit when i open it it just thinks for a long time then stops
    I have tried
    -running as administrator (same thing happened)
    -restart then run it another time (same thing happened)
    -it is in a read right folder
    my computer has
    2 2.33GHz processors
    4GB RAM
    64-bit OP
    Windows 7 Ultimate Service pack 1
    NVIDIA Quadro FX 350M card
    help as soon as posible.
    Thank you
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: autodesk failing to install
    04-25-2012 07:13 AM in reply to: theoncomingstorm3
    Maybe it is a bad download?  You could try extracting it on another computer to see.  Once extracted, you can use the files to install anywhere.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    04-25-2012 02:22 PM in reply to: theoncomingstorm3
    after making my last mesage i found out that the file i got was not a true exe it was an arcive, when extracting it to a new folder winrar gave me 2 errors a corupted file error and a unexpected end to file error.
    I will atempt to get a new copy from the website and then update this post as to what happens.
    thankyou for the help.
    -TheOncimingStorm3
    Member
    04-25-2012 07:02 PM in reply to: TravisNave
    the setup now works but it will not accept my product key, it will take the serial number
    can you help?
    *Expert Elite*
    TravisNave
    04-26-2012 09:22 PM in reply to: theoncomingstorm3
    What product key are you trying to use?  They're all the same.
    Travis Nave
    Member
    04-27-2012 01:25 PM in reply to: theoncomingstorm3
    797D1
    philip.s
    05-01-2012 02:49 PM in reply to: theoncomingstorm3
    I apologize for the delayed response theoncomingstorm3.
    Are you still having this installation / activation issue? If so can you please send me a "Private Message" (click on my philip.s profile name, and then "Send this user a Private message") with your serial number and a screen shot of the error.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
