Installation & Licensing
autocad14 32bit to windows 7 64bit
2 REPLIES 2
adeasisjr
827 Views, 2 Replies
I recently purchased a 64 bit laptop for my new revit but still work with my old dependable Autocad 14. Is there anyway of installing Audocad 14 32 bit into a 64 bit laptop?
2 REPLIES 2
afif90
in reply to: adeasisjr
before u install & download.. double check u Workstation specification & Windows 32bit or 64bit..
Thank You&Best Regards,
Autodesk Reseller Malaysia
Mohd Afif
TravisNave
No.  You cannot run or activate AutoCAD 14 on WIndows 7-64 bit.  You might consider using a virtual machine and run an older Windows OS like Windows 2000.
Autodesk Forums:
Administrator Productivity
