Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
autocad is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I finally decided to just order a copy of the trial CDs and wait for them to arrive. They came yesterday, but I am unable to install autocad because the setup program thinks it is already installed.
I found the page that explains how to delete all autocad files from your computer and followed it, including going into the registry, however the folder under C
I am running windows 7, please help!
-Chris
Re: autocad is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://support.microsoft.com/kb/290301
Locate the offending AutoCAD program in the list and delete it. Then make sure you also remove the AutoCAD folder that was installed under your C:\Program Files folder. Reboot and attempt to reinstall.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: autocad is already installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
More help would be very appreciated.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HKLM > Software > Microsoft > Windows > CurrentVersion > Installer > UserData > S-1-5-18 > Components
You need to change the permissions of components so that the 'everyone' user has full control and effective permission and that it is replaced on the child objects below it. It may take multiple attempts and changing the ownership to the Administrators group, but your IT should be able to help. Alternately, you will have to fix each key with this problem, which can amount to dozens. This is a tedious problem to fix, but it can be done. I wish you luck on this one.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I know this thread is an old one but for those of you that come across it in a search for an answer to your problem please be aware that the uninstaller that is referenced was discontinued by Microsoft and a "troubleshooter" was substituted.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I should have said "cleanup utility" not uninstaller. My bad.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensi
