• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    thiagobrausa
    autocad architecture 2012 error 1603
    330 Views, 3 Replies
    02-05-2012 09:07 AM
    i need help with this, can someone help me solve this problem.
    i tried installing many times and same error shows over and over....
    i have the attachment so you can take a look.
    thanks
    New Member
    thiagobrausa
    Re: autocad architecture 2012 error 1603
    02-05-2012 09:19 AM in reply to: thiagobrausa
    2012/2/3:21:31:19    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/3:21:31:19    Thiago    AMBROSIO    Launch
    2012/2/3:21:32:55    Thiago    AMBROSIO    === Setup ended ===
    2012/2/3:21:32:56    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/3:21:33:40    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/3:21:33:46    Thiago    AMBROSIO    PageOpen    ProductInfoDialog
    2012/2/3:21:37:13    Thiago    AMBROSIO    PageOpen    ProductSelectionDialog2
    2012/2/3:21:37:24    Thiago    AMBROSIO    PageOpen    FullProgressDialog
    2012/2/3:21:37:24    Thiago    AMBROSIO    Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
    2012/2/3:21:46:16    Thiago    AMBROSIO    Install    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1603
    2012/2/3:21:46:19    Thiago    AMBROSIO    PageOpen    InstallCompleteDialog
    2012/2/3:21:47:42    Thiago    AMBROSIO    === Setup ended ===
    2012/2/3:22:09:42    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/3:22:09:42    Thiago    AMBROSIO    Launch
    2012/2/3:22:11:19    Thiago    AMBROSIO    === Setup ended ===
    2012/2/3:22:09:45    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/3:22:09:45    Thiago    AMBROSIO    Launch
    2012/2/3:22:11:21    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/3:22:23:11    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/3:22:23:11    Thiago    AMBROSIO    PageOpen    ProductSelectionDialog2
    2012/2/3:22:23:33    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/3:22:23:33    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/3:22:23:59    Thiago    AMBROSIO    PageOpen    BeginDeploymentDialog
    2012/2/3:22:24:18    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/3:22:24:29    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/3:22:24:34    Thiago    AMBROSIO    PageOpen    ProductInfoDialog
    2012/2/3:22:25:25    Thiago    AMBROSIO    PageOpen    ProductSelectionDialog2
    2012/2/3:22:26:54    Thiago    AMBROSIO    PageOpen    FullProgressDialog
    2012/2/3:22:26:55    Thiago    AMBROSIO    Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
    2012/2/3:22:38:10    Thiago    AMBROSIO    Install    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1603
    2012/2/3:22:38:12    Thiago    AMBROSIO    PageOpen    InstallCompleteDialog
    2012/2/4:01:01:34    Thiago    AMBROSIO    === Setup ended ===
    2012/2/4:13:19:58    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/4:13:19:58    Thiago    AMBROSIO    Launch
    2012/2/4:13:21:48    Thiago    AMBROSIO    === Setup ended ===
    2012/2/4:13:20:03    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/4:13:20:03    Thiago    AMBROSIO    Launch
    2012/2/4:13:21:50    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/4:17:05:01    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/4:17:05:17    Thiago    AMBROSIO    PageOpen    ProductInfoDialog
    2012/2/4:17:05:21    Thiago    AMBROSIO    PageOpen    ProductSelectionDialog2
    2012/2/4:17:05:29    Thiago    AMBROSIO    PageOpen    FullProgressDialog
    2012/2/4:17:05:29    Thiago    AMBROSIO    Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
    2012/2/4:17:14:44    Thiago    AMBROSIO    Install    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1603
    2012/2/4:17:14:47    Thiago    AMBROSIO    PageOpen    InstallCompleteDialog
    2012/2/4:17:15:48    Thiago    AMBROSIO    === Setup ended ===
    2012/2/4:18:47:03    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/4:18:47:03    Thiago    AMBROSIO    Launch
    2012/2/4:18:47:55    Thiago    AMBROSIO    === Setup ended ===
    2012/2/4:18:47:06    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/4:18:47:06    Thiago    AMBROSIO    Launch
    2012/2/4:18:48:02    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/4:18:50:54    Thiago    AMBROSIO    You are attempting to use a 32-bit installer on a 64-bit operating system.
    Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/2/4:18:51:17    Thiago    AMBROSIO    === Setup ended ===
    2012/2/5:02:15:32    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/5:02:15:32    Thiago    AMBROSIO    Launch
    2012/2/5:02:17:53    Thiago    AMBROSIO    === Setup ended ===
    2012/2/5:02:15:33    Thiago    AMBROSIO    === Setup started on AMBROSIO by Thiago ===
    2012/2/5:02:15:33    Thiago    AMBROSIO    Launch
    2012/2/5:02:17:57    Thiago    AMBROSIO    PageOpen    LaunchDialog
    2012/2/5:03:04:18    Thiago    AMBROSIO    PageOpen    LicenseDialog
    2012/2/5:03:04:24    Thiago    AMBROSIO    PageOpen    ProductInfoDialog
    2012/2/5:03:04:35    Thiago    AMBROSIO    PageOpen    ProductSelectionDialog2
    2012/2/5:03:04:42    Thiago    AMBROSIO    PageOpen    FullProgressDialog
    2012/2/5:03:04:43    Thiago    AMBROSIO    Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_64Bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
    2012/2/5:03:20:54    Thiago    AMBROSIO    Install    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1603
    ***Guru
    TravisNave
    02-06-2012 09:51 AM in reply to: thiagobrausa
    Per our PM message offline, please let me know if the .NET Framework cleanup tool and reinstall of AutoCAD solved your issue.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    ***Guru
    TravisNave
    02-08-2012 07:25 AM in reply to: thiagobrausa
    Per our continued PM string, your PIT issue can be resolved by deleting your ProductInformation.pit file per this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540825&linkID=9241177
