hi,
One day the programm stops working ( windows just close it) and every time I try to open it I get email from autodesk with autorisation code (Autodesk Registration & Activations: AutoCAD LT 2013). A problem is that I can't activate the product becouse windows close it during openning. Someone knows what to do?
This ia written in logs:
Faulting application name: LMU.exe, version: 5.0.39.0, time stamp: 0x4f0e4fd7
Faulting module name: adlmact_libFNP.dll, version: 11.10.0.0, time stamp: 0x4dde38fe
Exception code: 0xc000000d
Fault offset: 0x0000000000192b71
Faulting process id: 0x1324
Faulting application start time: 0x01cf5d5e6fb00ff5
Faulting application path: C:\Program Files\Common Files\Autodesk Shared\Adlm\R5\LMU.exe
Faulting module path: C:\Program Files\Common Files\Autodesk Shared\Adlm\R5\adlmact_libFNP.dll
Report Id: b2b0c8c0-c952-11e3-b7ac-0090f58a2751
any idea?
This is because the files of C:\Program Files\Common Files\Autodesk Shared\Adlm\R5 were corrupted. Try to uninstall the product, and delete above folder manually, then reinstall, see if works.
Regretfully, it dosn't work. I deleted all autodesk files, that I manage to find and still same crash during autorization.
Any idias?
