Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
autocad 2013 installation error
3 REPLIES 3
3196 Views, 3 Replies
everytime i try to install the trail version of autocad architecture i get an error as soon as i run the install its states  a software problem has caused autodesk installer to close unexpectedly. i am running autocad 2012 and have no issues with that program installing but i cannot get 2013 to install, no matter what i do. i have made sure all computer updates were installed and checked for the microsoft.net 4.0 frameworks. i cannot figure out why this will not install. i am running windows 7, 64 bit. any help would be appreciated
3 REPLIES 3
TravisNave
Try installing logged in as another user with local admin rights, UAC off, and anti-virus disabled.
Autodesk Forums:
Did this work?  I am having the same problem and it didn't help.  It is initializing then the error pops up software problem has caused Autodesk Installer to close unexpectedly.
Any help would be appreciated
Has anyone found a solution to this problem yet?
Administrator Productivity
