Installation & Licensing
"Installation complete. Some products failed to install." HELP
2 REPLIES 2
dcarq_3m
300 Views, 2 Replies
Could you kindly check this.
Many thanks
2014/3/27:21:11:52 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/27:21:11:52 Jolynn JOLYN Path_Length: 155
2014/3/27:21:11:52 Jolynn JOLYN Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/3/27:21:11:52 Jolynn JOLYN Launch
2014/3/27:21:11:52 Jolynn JOLYN CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/3/27:21:11:52 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI295.tmp
2014/3/27:21:12:01 Jolynn JOLYN === Setup ended ===
2014/3/27:21:11:54 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/27:21:11:54 Jolynn JOLYN Path_Length: 155
2014/3/27:21:11:54 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI295.tmp
2014/3/27:21:11:54 Jolynn JOLYN Launch
2014/3/27:21:11:58 Jolynn JOLYN PageOpen MaintenanceDialog
2014/3/27:21:12:02 Jolynn JOLYN PageOpen MaintVerifyReadyDialog
2014/3/27:21:12:06 Jolynn JOLYN PageOpen FullProgressDialog
2014/3/27:21:12:06 Jolynn JOLYN Installing Autodesk® AutoCAD® 2014:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/3/27:21:13:05 Jolynn JOLYN Uninstall Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1602
2014/3/27:21:13:05 Jolynn JOLYN PageOpen MaintFailedDialog
2014/3/27:21:13:10 Jolynn JOLYN === Setup ended ===
2014/3/29:19:35:43 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:19:35:43 Jolynn JOLYN Path_Length: 155
2014/3/29:19:35:43 Jolynn JOLYN Current Directory C:\Program Files\Autodesk\AutoCAD 2014\Setup\en-us\Setup
2014/3/29:19:35:43 Jolynn JOLYN Launch
2014/3/29:19:35:43 Jolynn JOLYN CommandLine /P {5783F2D7-D001-0000-0102-0060B0CE6BBA} /M ACAD /language en-US
2014/3/29:19:35:43 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIB40A.tmp
2014/3/29:19:35:47 Jolynn JOLYN === Setup ended ===
2014/3/29:19:35:44 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:19:35:44 Jolynn JOLYN Path_Length: 155
2014/3/29:19:35:44 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIB40A.tmp
2014/3/29:19:35:44 Jolynn JOLYN Launch
2014/3/29:19:35:47 Jolynn JOLYN PageOpen MaintenanceDialog
2014/3/29:19:35:50 Jolynn JOLYN PageOpen MaintVerifyReadyDialog
2014/3/29:19:35:54 Jolynn JOLYN PageOpen FullProgressDialog
2014/3/29:19:35:55 Jolynn JOLYN Installing Autodesk® AutoCAD® 2014:  REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/3/29:19:39:16 Jolynn JOLYN Reinstall/uninstall  Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-1102-0060B0CE6BBA}) Succeeded
2014/3/29:19:39:22 Jolynn JOLYN Reinstall/uninstall  Autodesk® AutoCAD® 2014 ({5783F2D7-D001-0409-2102-0060B0CE6BBA}) Succeeded
2014/3/29:19:39:22 Jolynn JOLYN Uninstall Autodesk® AutoCAD® 2014 Succeeded
2014/3/29:19:39:22 Jolynn JOLYN PageOpen MaintCompleteDialog
2014/3/29:19:52:15 Jolynn JOLYN === Setup ended ===
2014/3/29:19:55:51 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:19:55:51 Jolynn JOLYN Path_Length: 155
2014/3/29:19:55:51 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/3/29:19:55:51 Jolynn JOLYN Launch
2014/3/29:19:55:51 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/3/29:19:55:51 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI2097.tmp
2014/3/29:19:58:14 Jolynn JOLYN === Setup ended ===
2014/3/29:19:55:54 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:19:55:54 Jolynn JOLYN Path_Length: 155
2014/3/29:19:55:54 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI2097.tmp
2014/3/29:19:55:54 Jolynn JOLYN Launch
2014/3/29:19:56:00 Jolynn JOLYN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/29:19:58:13 Jolynn JOLYN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/29:19:58:13 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI2097.tmp\Setup\AcSetup.dll
2014/3/29:19:58:13 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/29:19:58:14 Jolynn JOLYN PageOpen LaunchDialog
2014/3/29:19:58:40 Jolynn JOLYN PageOpen LicenseDialog
2014/3/29:19:58:40 Jolynn JOLYN PageOpen ProductInfoDialog
2014/3/29:19:59:43 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/3/29:20:00:00 Jolynn JOLYN PageOpen FullProgressDialog
2014/3/29:20:00:00 Jolynn JOLYN Download Play DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/3/29:20:03:05 Jolynn JOLYN Download Complete DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/3/29:20:03:05 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/3/29:20:03:12 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/3/29:20:03:12 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/3/29:20:03:20 Jolynn JOLYN === Setup ended ===
2014/3/29:20:07:44 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:20:07:44 Jolynn JOLYN Path_Length: 155
2014/3/29:20:07:44 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/3/29:20:07:44 Jolynn JOLYN Launch
2014/3/29:20:07:44 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/3/29:20:07:44 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI336.tmp
2014/3/29:20:07:46 Jolynn JOLYN === Setup ended ===
2014/3/29:20:07:45 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/3/29:20:07:45 Jolynn JOLYN Path_Length: 155
2014/3/29:20:07:45 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI336.tmp
2014/3/29:20:07:45 Jolynn JOLYN Launch
2014/3/29:20:07:45 Jolynn JOLYN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/3/29:20:07:45 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI336.tmp\Setup\AcSetup.dll
2014/3/29:20:07:45 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/29:20:07:46 Jolynn JOLYN PageOpen LaunchDialog
2014/3/29:20:07:51 Jolynn JOLYN PageOpen LicenseDialog
2014/3/29:20:07:51 Jolynn JOLYN PageOpen ProductInfoDialog
2014/3/29:20:07:56 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/3/29:20:08:19 Jolynn JOLYN PageOpen FullProgressDialog
2014/3/29:20:08:20 Jolynn JOLYN Download Skipped DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/3/29:20:08:20 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/3/29:20:08:26 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/3/29:20:08:26 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/3/29:20:08:41 Jolynn JOLYN === Setup ended ===
2014/4/2:20:28:25 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:28:25 Jolynn JOLYN Path_Length: 155
2014/4/2:20:28:25 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/2:20:28:25 Jolynn JOLYN Launch
2014/4/2:20:28:25 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-19282179 /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/2:20:28:25 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI72B8.tmp
2014/4/2:20:28:30 Jolynn JOLYN === Setup ended ===
2014/4/2:20:28:26 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:28:26 Jolynn JOLYN Path_Length: 155
2014/4/2:20:28:26 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI72B8.tmp
2014/4/2:20:28:26 Jolynn JOLYN Launch
2014/4/2:20:28:29 Jolynn JOLYN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/2:20:28:29 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI72B8.tmp\Setup\AcSetup.dll
2014/4/2:20:28:29 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/2:20:28:30 Jolynn JOLYN PageOpen LaunchDialog
2014/4/2:20:28:44 Jolynn JOLYN PageOpen LicenseDialog
2014/4/2:20:28:44 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/2:20:28:44 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/2:20:32:55 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/2:20:32:55 Jolynn JOLYN Download Skipped DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/4/2:20:32:55 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/2:20:33:02 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/2:20:33:02 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/2:20:33:48 Jolynn JOLYN === Setup ended ===
2014/4/2:20:48:26 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:48:26 Jolynn JOLYN Path_Length: 155
2014/4/2:20:48:26 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIC594.tmp
2014/4/2:20:48:26 Jolynn JOLYN Launch
2014/4/2:20:48:47 Jolynn JOLYN === Setup ended ===
2014/4/2:20:48:25 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:48:25 Jolynn JOLYN Path_Length: 155
2014/4/2:20:48:25 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/2:20:48:25 Jolynn JOLYN Launch
2014/4/2:20:48:25 Jolynn JOLYN CommandLine
2014/4/2:20:48:25 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIC594.tmp
2014/4/2:20:48:48 Jolynn JOLYN === Setup ended ===
2014/4/2:20:49:13 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:49:13 Jolynn JOLYN Path_Length: 155
2014/4/2:20:49:13 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI7C12.tmp
2014/4/2:20:49:13 Jolynn JOLYN Launch
2014/4/2:20:49:15 Jolynn JOLYN === Setup ended ===
2014/4/2:20:49:12 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:20:49:12 Jolynn JOLYN Path_Length: 155
2014/4/2:20:49:12 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/2:20:49:12 Jolynn JOLYN Launch
2014/4/2:20:49:12 Jolynn JOLYN CommandLine
2014/4/2:20:49:12 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI7C12.tmp
2014/4/2:21:37:39 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:37:39 Jolynn JOLYN Path_Length: 155
2014/4/2:21:37:39 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2014/4/2:21:37:39 Jolynn JOLYN Launch
2014/4/2:21:37:39 Jolynn JOLYN CommandLine
2014/4/2:21:37:39 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AID6EE.tmp
2014/4/2:21:37:54 Jolynn JOLYN === Setup ended ===
2014/4/2:21:37:42 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:37:42 Jolynn JOLYN Path_Length: 155
2014/4/2:21:37:42 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AID6EE.tmp
2014/4/2:21:37:42 Jolynn JOLYN Launch
2014/4/2:21:37:43 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AID6EE.tmp\Setup\AcSetup.dll
2014/4/2:21:37:43 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/2:21:37:54 Jolynn JOLYN PageOpen LaunchDialog
2014/4/2:21:37:58 Jolynn JOLYN PageOpen LicenseDialog
2014/4/2:21:38:02 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/2:21:38:47 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/2:21:38:57 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/2:21:38:58 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/2:21:39:04 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/2:21:39:04 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/2:21:39:12 Jolynn JOLYN === Setup ended ===
2014/4/2:21:39:34 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:39:34 Jolynn JOLYN Path_Length: 155
2014/4/2:21:39:34 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2014/4/2:21:39:34 Jolynn JOLYN Launch
2014/4/2:21:39:34 Jolynn JOLYN CommandLine
2014/4/2:21:39:34 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI98F1.tmp
2014/4/2:21:39:37 Jolynn JOLYN === Setup ended ===
2014/4/2:21:39:35 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:39:35 Jolynn JOLYN Path_Length: 155
2014/4/2:21:39:35 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI98F1.tmp
2014/4/2:21:39:35 Jolynn JOLYN Launch
2014/4/2:21:39:35 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI98F1.tmp\Setup\AcSetup.dll
2014/4/2:21:39:35 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/2:21:39:37 Jolynn JOLYN PageOpen LaunchDialog
2014/4/2:21:39:38 Jolynn JOLYN PageOpen LicenseDialog
2014/4/2:21:39:41 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/2:21:40:05 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/2:21:40:33 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/2:21:40:33 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/2:21:40:40 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/2:21:40:40 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/2:21:40:43 Jolynn JOLYN === Setup ended ===
2014/4/2:21:41:23 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:41:23 Jolynn JOLYN Path_Length: 155
2014/4/2:21:41:23 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2014/4/2:21:41:23 Jolynn JOLYN Launch
2014/4/2:21:41:23 Jolynn JOLYN CommandLine
2014/4/2:21:41:23 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI4336.tmp
2014/4/2:21:41:26 Jolynn JOLYN === Setup ended ===
2014/4/2:21:41:24 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/2:21:41:24 Jolynn JOLYN Path_Length: 155
2014/4/2:21:41:24 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI4336.tmp
2014/4/2:21:41:24 Jolynn JOLYN Launch
2014/4/2:21:41:25 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI4336.tmp\Setup\AcSetup.dll
2014/4/2:21:41:25 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/2:21:41:26 Jolynn JOLYN PageOpen LaunchDialog
2014/4/2:21:41:29 Jolynn JOLYN PageOpen LicenseDialog
2014/4/2:21:41:32 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/2:21:41:55 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/2:21:42:00 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/2:21:42:01 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/2:21:42:07 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/2:21:42:07 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/2:21:42:37 Jolynn JOLYN === Setup ended ===
2014/4/3:19:50:42 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:19:50:42 Jolynn JOLYN Path_Length: 155
2014/4/3:19:50:42 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2014/4/3:19:50:42 Jolynn JOLYN Launch
2014/4/3:19:50:42 Jolynn JOLYN CommandLine
2014/4/3:19:50:42 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI4932.tmp
2014/4/3:19:51:01 Jolynn JOLYN === Setup ended ===
2014/4/3:19:50:43 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:19:50:43 Jolynn JOLYN Path_Length: 155
2014/4/3:19:50:43 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI4932.tmp
2014/4/3:19:50:43 Jolynn JOLYN Launch
2014/4/3:19:50:44 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI4932.tmp\Setup\AcSetup.dll
2014/4/3:19:50:44 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:19:51:02 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:19:53:26 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:19:53:30 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:19:53:50 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/3:19:53:54 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/3:19:53:54 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/3:19:54:01 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/3:19:54:01 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/3:19:55:41 Jolynn JOLYN === Setup ended ===
2014/4/3:20:14:19 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:14:19 Jolynn JOLYN Path_Length: 155
2014/4/3:20:14:19 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2014/4/3:20:14:19 Jolynn JOLYN Launch
2014/4/3:20:14:19 Jolynn JOLYN CommandLine
2014/4/3:20:14:19 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIE992.tmp
2014/4/3:20:14:22 Jolynn JOLYN === Setup ended ===
2014/4/3:20:14:20 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:14:20 Jolynn JOLYN Path_Length: 155
2014/4/3:20:14:20 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIE992.tmp
2014/4/3:20:14:20 Jolynn JOLYN Launch
2014/4/3:20:14:20 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AIE992.tmp\Setup\AcSetup.dll
2014/4/3:20:14:20 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:20:14:22 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:20:14:24 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:20:14:27 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:20:16:00 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:20:16:02 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:20:18:33 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:20:18:46 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:20:20:53 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/3:20:23:26 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/3:20:23:27 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/3:20:23:33 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/3:20:23:33 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/3:20:32:34 Jolynn JOLYN === Setup ended ===
2014/4/3:20:54:06 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:54:06 Jolynn JOLYN Path_Length: 155
2014/4/3:20:54:06 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:54:06 Jolynn JOLYN Launch
2014/4/3:20:54:06 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-19282179 /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/3:20:54:06 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI5369.tmp
2014/4/3:20:54:10 Jolynn JOLYN === Setup ended ===
2014/4/3:20:54:09 Jolynn JOLYN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/3:20:54:09 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI5369.tmp\Setup\AcSetup.dll
2014/4/3:20:54:09 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:20:54:09 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:20:54:17 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:20:54:17 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:20:54:17 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/3:20:54:21 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/3:20:54:22 Jolynn JOLYN Download Skipped DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/4/3:20:54:22 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/3:20:54:28 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/3:20:54:28 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/3:20:54:33 Jolynn JOLYN === Setup ended ===
2014/4/3:20:55:21 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:55:21 Jolynn JOLYN Path_Length: 155
2014/4/3:20:55:21 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:55:21 Jolynn JOLYN Launch
2014/4/3:20:55:21 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-19282179 /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/3:20:55:21 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI7A65.tmp
2014/4/3:20:55:23 Jolynn JOLYN === Setup ended ===
2014/4/3:20:55:22 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:55:22 Jolynn JOLYN Path_Length: 155
2014/4/3:20:55:22 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI7A65.tmp
2014/4/3:20:55:22 Jolynn JOLYN Launch
2014/4/3:20:55:23 Jolynn JOLYN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/3:20:55:23 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AI7A65.tmp\Setup\AcSetup.dll
2014/4/3:20:55:23 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:20:55:23 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:20:55:30 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:20:55:30 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:20:55:30 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/3:20:55:47 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/3:20:55:47 Jolynn JOLYN Download Skipped DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/4/3:20:55:47 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/3:20:55:53 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/4/3:20:55:53 Jolynn JOLYN PageOpen InstallCompleteDialog
2014/4/3:20:56:00 Jolynn JOLYN === Setup ended ===
2014/4/3:20:56:35 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:56:35 Jolynn JOLYN Path_Length: 155
2014/4/3:20:56:35 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:56:35 Jolynn JOLYN Launch
2014/4/3:20:56:35 Jolynn JOLYN CommandLine
2014/4/3:20:56:35 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI9B55.tmp
2014/4/3:20:56:54 Jolynn JOLYN === Setup ended ===
2014/4/3:20:56:36 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:56:36 Jolynn JOLYN Path_Length: 155
2014/4/3:20:56:36 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI9B55.tmp
2014/4/3:20:56:36 Jolynn JOLYN Launch
2014/4/3:20:56:55 Jolynn JOLYN === Setup ended ===
2014/4/3:20:56:58 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:56:58 Jolynn JOLYN Path_Length: 155
2014/4/3:20:56:58 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:56:58 Jolynn JOLYN Launch
2014/4/3:20:56:58 Jolynn JOLYN CommandLine
2014/4/3:20:56:58 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIF4D0.tmp
2014/4/3:20:57:01 Jolynn JOLYN === Setup ended ===
2014/4/3:20:56:59 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:56:59 Jolynn JOLYN Path_Length: 155
2014/4/3:20:56:59 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIF4D0.tmp
2014/4/3:20:56:59 Jolynn JOLYN Launch
2014/4/3:20:57:02 Jolynn JOLYN === Setup ended ===
2014/4/3:20:57:30 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:57:30 Jolynn JOLYN Path_Length: 155
2014/4/3:20:57:30 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:57:30 Jolynn JOLYN Launch
2014/4/3:20:57:30 Jolynn JOLYN CommandLine
2014/4/3:20:57:30 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI7097.tmp
2014/4/3:20:57:38 Jolynn JOLYN === Setup ended ===
2014/4/3:20:57:39 Jolynn JOLYN === Setup ended ===
2014/4/3:20:58:18 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:58:18 Jolynn JOLYN Path_Length: 155
2014/4/3:20:58:18 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:20:58:18 Jolynn JOLYN Launch
2014/4/3:20:58:18 Jolynn JOLYN CommandLine
2014/4/3:20:58:18 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI2E98.tmp
2014/4/3:20:58:30 Jolynn JOLYN === Setup ended ===
2014/4/3:20:58:19 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:20:58:19 Jolynn JOLYN Path_Length: 155
2014/4/3:20:58:19 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AI2E98.tmp
2014/4/3:20:58:19 Jolynn JOLYN Launch
2014/4/3:20:58:31 Jolynn JOLYN === Setup ended ===
2014/4/3:21:00:09 Jolynn JOLYN === Setup started on JOLYN by Jolynn ===
2014/4/3:21:00:09 Jolynn JOLYN Path_Length: 155
2014/4/3:21:00:09 Jolynn JOLYN Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/4/3:21:00:09 Jolynn JOLYN Launch
2014/4/3:21:00:09 Jolynn JOLYN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setu... /SN 900-19282179 /PK 001F1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/3:21:00:09 Jolynn JOLYN Current Directory C:\Users\JOHANN~1\AppData\Local\Temp\_AIDCD4.tmp
2014/4/3:21:00:11 Jolynn JOLYN === Setup ended ===
2014/4/3:21:00:10 Jolynn JOLYN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/SETUP_x6...
2014/4/3:21:00:10 Jolynn JOLYN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JOHANN~1\AppData\Local\Temp\_AIDCD4.tmp\Setup\AcSetup.dll
2014/4/3:21:00:10 Jolynn JOLYN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:21:00:11 Jolynn JOLYN PageOpen LaunchDialog
2014/4/3:21:00:16 Jolynn JOLYN PageOpen LicenseDialog
2014/4/3:21:00:16 Jolynn JOLYN PageOpen ProductInfoDialog
2014/4/3:21:00:16 Jolynn JOLYN PageOpen ProductSelectionDialog2
2014/4/3:21:00:21 Jolynn JOLYN PageOpen FullProgressDialog
2014/4/3:21:00:21 Jolynn JOLYN Download Skipped DOTNET4LANG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7}/DOTNET4K...
2014/4/3:21:00:21 Jolynn JOLYN Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2014/4/3:21:00:27 Jolynn JOLYN Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2 REPLIES 2
TravisNave
in reply to: dcarq_3m
I answered this in your other post.
Your failure is a prerequisite here:
 Uninstall the .NET or run the .NET Cleanup Utility if that doesn't work.
Autodesk Forums:
dcarq_3m
Many thanks for your reply.
However, It seems quite difficult for me this lenguage and more to do changes in the pc's software that is already set. I went for the safe and downloaded an older AutoCAD version. Perhaps, it will be great to avoid this issue from Autodesk since many people have it.
Regards.
Administrator Productivity
