Installation & Licensing
dbounds
Message 1 of 6 (124 Views)
adLm can't connect
124 Views, 5 Replies
02-04-2002 09:33 PM
for Inventor 5, we have the ADLM set up and Inventor installed but go to run Inventor and get this message.
License Server Host Unknown
Dan
*martin, jason
Message 2 of 6 (122 Views)
Re: adLm can't connect
02-04-2002 09:50 PM in reply to: dbounds
Dan -
Please bear with me, I'm an inventor idjit.
What type of licensing does inventor 5 use? I understand that it uses Adlm, but there are two different "versions" of the adlm and
they exhibit completely different problems (in some cases). Do you know if it is based on Elan technology or FlexLM technology? Did
you get a license "file" or an authorization "code"?
Did you use the setup in the netsetup folder (and I'm just assuming that there is a netsetup folder in IV)?
The error License Server Host Unknown would lead me to believe that you are having host name resolution problems (but I'm completely
guessing). Can you give me some background on your network. DNS servers? Wins servers? TCP/IP I'm hoping?
jason martin
frankfurt-short-bruza
Member of the Autodesk Discussion Forum Moderator Program
"dbounds" wrote in message news:f0b4662.-1@WebX.maYIadrTaRb...
> Thanks,
> Dan
dbounds
Message 3 of 6 (122 Views)
Re:
02-04-2002 10:20 PM in reply to: dbounds
You do it just like autocad or MDT when using the ADLM, which we are using.
Trouble is, this installation is at another plant (in MO) and I'm in PA. I have set it up here with Elan ADLM with no problem. It the ADLM from the Rel. 14 CD. I just added Inventor with no problem.
They got all the codes and added the licenses (312 came up with 4 licenses) to the ADLM.
They installed it on a shared (G:smileyhappy: drive. I installed mine on the root (C:smileyhappy: drive of the server.
What I thougth it sounded like was that the user couldn't see the share drive they installed it on. That's what they are checking into presently.
Dan
dbounds
Message 4 of 6 (122 Views)
Re:
02-04-2002 10:52 PM in reply to: dbounds
As for network installation for client deployment - it is a little different than AutoCAD based products. Microsoft scripting (MSIEXE.EXE) is used. The format is MSIEXE /a SETUP.MSI then follow the prompts. I am trying to see if they setup the network deployment folder this way.
Dan
*martin, jason
Message 5 of 6 (122 Views)
Re:
02-05-2002 12:17 AM in reply to: dbounds
Dan -
It shouldn't matter whether or not the users can see the share. The files have nothing to do with the actual granting of licenses.
The licenses are issued via tcp/ip only and the actual files are never accessed by the client.
Are you sure that the Adlm service is actually running? You have to go to control panel and start it the first time (I don't
remember if it's set to manual by default or not, but it's something to check). After you start the service you have to wait for 3
minutes while it looks around before it will issue a license.
jason martin
"dbounds" wrote in message news:f0b4662.1@WebX.maYIadrTaRb...
into presently.
> Thanks,
> Dan
*Ahava, Petri
Message 6 of 6 (123 Views)
Re:
02-05-2002 02:04 AM in reply to: dbounds
if it's crying about the server host, it has to be a nw version you have
installed. Check that these workstations don't have an acadserver
variable set to a wrong server! Also check that the workstations can
ping the server by name and vice versa! If not, you'll have to fix your
nameresolution. Also check that the workstations are running the same
system time. MAybe the adlm that's on the R14 CD is too old? Download
the Inv. 4 adlm from:
ftp://adeskftp.autodesk.com/prodsupp/inventor/inv4_lic_server.zip
That's all I can think about right now. 5.3 will be using the FlexLM so
if you are on a subscription, maybe you shouldn't work on this too much?
HTH
Petri Ahava
CAD-Q Finland
> Thanks,
> Dan
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
