I installed Autocad 2010 in my Laptop, with the serial number and product key.
At the time of running, it was failed to activate due to serial number is not ok. can u pls inform me the serial number mentioned on the box, it also make the thinga like this.
Can u please check and reply ,me ASAP.
regards,
Amit Patel
If your product was upgraded and not kept under active Subscription, the lease probably expired. If you never activated a newer version, you might be able to still get an activation code. Perhaps philip.s can get you started on that.
I certainly can Travis 🙂
Amit, as I was unable to find any licenses associated with your registered email, can you please send me Private Message (click on my philip.s profile name and then "Send this user a private message") with the serial number that you had attempted to activate with as well as any additional relevant information.
