• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    activation of product Autocad 2010
    1250 Views, 3 Replies
    10-23-2012 11:32 PM
    I installed Autocad 2010 in my Laptop, with the serial number and product key.
    At the time of running, it was failed to activate due to serial number is not ok. can u pls inform me the serial number mentioned on the box, it also make the thinga like this.
    Can u please check and reply ,me ASAP.
    regards,
    Amit Patel
    Please use plain text.
    jerome.pineau
    Re: activation of product Autocad 2010
    10-24-2012 06:41 AM in reply to: aapatel29
    Hi Amit, I've moved your post here as it will get quicker attention within that board.
    Best,
    J.
    Jerome Pineau
    AutodeskHelp | Social Media Strategist
    twitter.com/AutodeskHelp
    jerome.pineau@autodesk.com
    *Expert Elite*
    TravisNave
    10-24-2012 09:31 AM in reply to: aapatel29
    If your product was upgraded and not kept under active Subscription, the lease probably expired.  If you never activated a newer version, you might be able to still get an activation code.  Perhaps philip.s can get you started on that.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    philip.s
    10-24-2012 11:39 AM in reply to: TravisNave
    I certainly can Travis :smileyhappy:
    Amit, as I was unable to find any licenses associated with your registered email, can you please send me Private Message (click on my philip.s profile name and then "Send this user a private message") with the serial number that you had attempted to activate with as well as any additional relevant information.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
