Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
acad 11 transfer utility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to transfer acad 11 license from an old laptop to a new laptop. I have acad 11 loaded on there new laptop and it is working in the unlicensed mode. The license from the old laptop has been transferred using the license transfer in that computer. The license transfer utility opens in the new computer to the point where you are to sign in, but when I click on the sign in, I get a blank screen. I have reinstalled acad 11 on the new computer several times, I also have tried the repair, but I get the same result each time. How do I get to the sign in to import the license to the new computer?
Re: acad 11 transfer utility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The License Transfer Utilty doesn't work. Have you tried simply activating your reinstalled product online? Worst case, you can get an activation code manually from Autodesk Activations if your license is still active.
http://en.autodesk.ca/adsk/servlet/index?siteID=97
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: acad 11 transfer utility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The link you gave me gets me to the registration and activation site. There is no path to the file transfer utility.
I have the same problem if try to re activate the product. I get to the sign in screen and when I select sign in, the screen goes blank. I was able to sign in through link you gave me, but it asked me for a request code and I do not have one since i cannot sign in through the acad 11 registration site or file transfer utility
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensi
