Installation & Licensing
CJAbreu
2721 Views, 2 Replies
ac1st17.dll
I have an error when trying to read autocad files.  It states that the ac1st17.dll file is missing.  How can I recover this file, so that reading is operable again?  Thank you.
2 REPLIES 2
TravisNave
in reply to: CJAbreu
Did you do a search on your PC for it?
Might start here:
http://usa.autodesk.com/adsk/servlet/u/gsearch/results?siteID=123112&catID=123155&id=2088334&qt=ac1s...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
CJAbreu
in reply to: TravisNave
The file cannot be found anywhere.  Auocad has been uninstalled and reinstalled, as well as uninstalling pieces before the master program.  I read something in another article...  Is it possible that the file can live in some of the locations that it can be found in, while being gone in others?  If so, can I copy and paste the ones that are there into where they need to be?
Administrator Productivity
