Installation & Licensing
Your product cannot be registered in the United States (7)
1 REPLY 1
341 Views, 1 Reply
Good afternoon, We possess an hard dvd copy of Autodesk 3DS Max 2009 and use to run a network base licensing borrow system, which works well. Thing is that the service running the LMTools must be switch to a new server. If I'm correct, we need a new license file for the license to run on a different machine, so I've tried to register our product online and get a new license, but the registering process fails, it says that it cannot be registered in the US. It is a hard copy of the software (Assembled in Ireland, if I refer to the dvd case, don't think it's relevant) and we are located in Belgium. Can you help me figure out how to register our product and get a server license out of it? Regards, Samuel
1 REPLY 1
TravisNave
You can use the online method to activate your license here:
http://knowledge.autodesk.com/installation-and-licensing
Or you can can call Autodesk Product Registration and Authorization in your region:
Europe: 41.32.723.9595
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
